Page 275 of 570 FirstFirst ... 273274275276277 ... LastLast
Results 2,741 to 2,750 of 5693
  1. #2741
    Nov 2010
    Getting a life...
    38 Post(s)
    A dingo dozer rooftop tent for less than a packet of smokes...
    for the 'new' project.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  2. The Following 3 Users Say Thank You to katwoman For This Useful Post:
    BigRAWesty (22nd June 2016), Stropp (22nd June 2016), threedogs (22nd June 2016)
  3. #2742
    Tillix kit..
    Tillix kit..
    Would of thought you'd get a needle valve from Dependable over in SA
    BigRAWesty (24th June 2016)
  6. #2744
    Tillix is a good unit.
  7. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (24th June 2016), threedogs (26th June 2016)
  8. #2745
    Yea went tillix because of a few design differences over the dawes.
    Dropped into roadrunner and picked up a new HD tie rod, drag link and sway bar links (front & back)
  10. #2747
    I was with Barry on Sunday and as I was leaving the property I snapped my rear trailing arm! But that's okay as I had a spare under the back seat.
    Bloody bolts were seized on! So I had to drive home from willow Grove at 30km/h with the diff swaying around... Horrible feeling!
  11. The Following User Says Thank You to Winnie For This Useful Post:
    BigRAWesty (27th June 2016)
  12. #2748
    O dear was it a standard one? . . .
  13. #2749
    Yeah it was, and I have another standard to replace it.
    Must have been bent and kinked for a while without me noticing to snap like that, wasn't even in 4wd!
  14. #2750
    Brought two of these[well very similar] and some 50mmx 50mm terminal covers.
    The plan is to neaten up the terminals and then fit the rubber boots.
    http://www.ebay.com.au/itm/391492968...%3AMEBIDX%3AIT
    http://www.ebay.com.au/itm/161787744...%3AMEBIDX%3AIT
  15. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (10th July 2016)
