Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Siberian Patrol with burned clutch?
    84 Post(s)
    Another pro for a solid flywheel is that it can be machined, but a DMF has to be replaced . If it were me, I would replace the DMF or fit a solid one while I had the gear box separated any way. Some TD owners have switched to a solid flywheel, but since this thread is about an RD they might not read it.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    SiberianPatrol (26th June 2016)
  3. #12
    84 Post(s)
    This thread has the answer you seek.
    http://www.nissanpatrol.com.au/forum...solid+flywheel
  5. #13
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Thanks mate. Need to research the best brand I can get here. Who has done a clutch here before? What tools do I need to get the job done right? Since I'm out in the village, I need to make sure I have everything on hand before starting the project.
    1999 GU RD28Ti; mechanical injector pump, 5kBt Webasto circulation heater, 33" Yokohama Geolander I/T, SaaS boost & EGT gauges, 2" Ironman suspension...more to come
  6. #14
    Jul 2015
    Siberia
    Given the choice between and Exedy clutch or X-Treme Outback, which one is the better option?
  7. #15
    84 Post(s)
    I have an Exedy clutch. Early days yet as I have only done around 25000 Ks and no problem so far, but that has been mostly highway driving.
  8. The Following User Says Thank You to mudnut For This Useful Post:
    SiberianPatrol (27th June 2016)
