Page 87 of 101 FirstFirst ... 8586878889 ... LastLast
Results 861 to 870 of 1003
Thread: Hodge's new 4.2
  1. #861
    176 Post(s)
    Super cold this morning and no issue at all . I dunno. .. it's messing with my head .
    Car is now shelved for 2 weeks and then it's in for a clutch and I'll fill it with the oil you suggested.
  2. The Following User Says Thank You to Hodge For This Useful Post:
    Yeti's Beast (27th December 2016)
  3. #862
    Yeah. Leave the oil for a bit after the new clutch to see if the event still happens. No point changing it if it does turn out to be the clutch.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    Hodge (24th June 2016)
  5. #863
    You could take out the lsd and put an air locker in to see if that fixes it
  6. #864
    176 Post(s)
    Yeah definitely I'll see what results the clutch gives and the I'll go from there .
    176 Post(s)
    I've actually got a front locker with my name on it still waiting for me at ARB which I had to postpone due to clutch now.
    176 Post(s)
    Suspension. Check rear pinion angle. Run a double cardan joint on the rear shaft.
    Even going back to standard height will aleviate it.
    Not related to my car, but thought I'd mention it...
    Worked with a bloke today who owns a 2002 gu 4.2. He mentioned his awful gear chatter noise began after a 2 inch lift and was pretty bad.
    Apparently it is now much better after fixing the pinion angle with some upper arms and flipping the shaft around.
    No Idea why the shaft flip, but thumbs up Mat ! Remembered your comment on this when the bloke told me this was his fix.
    On a slightly more interesting note this car had just under 640k on clock ! I couldn't believe it. It did have a chassis swap at around 400k.
    Highest I've personally ever seen on a Patrol , maybe even on any vehicle.
  9. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    nissannewby (27th June 2016), Yeti's Beast (27th December 2016)
  10. #867
    I dont just say stuff for the sake of it...
    And like I said hodge
  11. The Following User Says Thank You to nissannewby For This Useful Post:
    Hodge (28th June 2016)
  12. #868
    176 Post(s)
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    @Hodge what kind of tyres are you running on the patrol?
    My brother in law just purchased a new ford ranger and was looking at purchasing an aggressive all terrain type, and I recalled you had something similar and we're happy with them? Cheers
  14. #870
    Check out jaysee's new boots,, very noice lol
