Results 11 to 20 of 33
Thread: Camping/Reverse lights
    Which is exactly what happened to me yesterday! !!! ( read the Queens birthday thred ). I have mine on a on/off/on switch. One is reverse centre is off and other is camp. Both fed from auxiliary battery. Switch is hidden when he got me to slot it in reverse and it didn't come on he was happy. Dodged a bullet .
    ROFL... there ya go then... the Defence rests.
  2. #12
    Ok quick q.i though you needed 2 relays. One for reverse and one for work light..
    With only one won't the reverse lights recive a positive feed from the switch when it's on??
    You can use a single change over relay if you want... Work light switch supplies 12 V to 87a (work selected) or 12 volts to 87 (rev selected) connect pin 30 to the work lights, relay switched by 12 volts on 85 from the reverse lights
    Work = work lights on thru 87a
    Rev = work lights on only when rev selected to energise relay to pin 87
    Off = nuffink 'cause there is no 12 volts (relay will still pull in tho)
    Fuse in the 12 volt to the switch protects the switch, wiring and lights
    Switching the relay via reverse doesn't load the reverse circuit
  3. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (21st June 2016)
  4. #13
    You can use a single change over relay if you want... Work light switch supplies 12 V to 87a (work selected) or 12 volts to 87 (rev selected) connect pin 30 to the work lights, relay switched by 12 volts on 86 from the reverse lights
    Fuse in the 12 volt to the switch protects the wiring and lights
    Augh yep.. simple..
    Expert Skitzyrex's Avatar
    Jul 2013
    Thank you everyone for your help.
    Still f$&ked though, just trying to draw it out. So far I've got:
    30 - to +ve on work lights
    87A - to switch then +ve on battery
    87 - to +ve on reverse
    85 - ?
    86 - ?
    Thanks for your patience people. Just struggle visualizing things
    2007 GU ST-S 4.8 Patrol.
    40mm heavy duty springs, Dual batteries,
    140 ltr fuel tank,Custom 60ltr water tank, draws, cargo barrier, bull bar, IPF spotties, UHF.
  6. #15
    Oct 2015
    Aldinga Beach SA
    Need to put a diode in to stop the feed. I had this problem and it blew the reverse light fuse and the car would not start - took a while to work out what happened....
    SOLD !!!!! White 2010 GU DX, bull bar, rear drawers, reversing camera, factory snorkel, pioneer roof rack, scangauge, dual battery, awning ....
  7. The Following User Says Thank You to Roosim For This Useful Post:
  8. #16
    177 Post(s)
    Here you go, this is how mine are wired. Single relay using the on/off/on switch.
  9. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (21st June 2016), Skitzyrex (21st June 2016)
  10. #17
    Jul 2013
    Thanks, think I'll just go down that path of having a on/off/on switch. Seems much easier. Cheers
  11. #18
    Quote Originally Posted by Skitzyrex View Post
    85 - ?
    86 - ?
    Battery positive to fuse then runs to centre pin (common) of 3 way switch (usually labelled as pin 2)
    87 - One pin of switch to 87 (this will power the lights when relay is energised) so is "Rev"
    87A - Other pin of switch to 87A (this will power the lights when relay deenrgised) so is "Work"
    85 - Reverse positive (lights, gearbox switch or whatever) to pin 85
    86 - Earth to pin 86
    30 - yes, as you stated, goes to work light supply
  12. The Following User Says Thank You to the evil twin For This Useful Post:
  13. #19
    Jul 2013
    Thank you Evil.
  14. #20
    Aug 2016
    QLD
    I need to do this too, I can't see a bloody thing backing up at night. Glad you guys mentioned installing an off option when in reverse. Didn't realise "The Man" would get so upset by it. I suppose I should know better by now that they get upset by almost everything. Would it be best to put the switch in the rear cargo area or in the cab? Or both?
