Results 1 to 10 of 12
Thread: Intro for Bobin51
    Oct 2015
    Mid North Coast
    Intro for Bobin51
    Hi folks is this how you introduce yourself I am a new computer user and just learning the ropes.I have a 2004 TDI 4.2 The best
    I have a question I was distracted this afternoon and by mistake pumped 8lts of petrol in the reserve tank of my diesal which was empty ,Does any one know how to drain the reserve tank, does it have to be removed or has it a drain plug at bottom of tank?
    Any help would be appreciated
    Thanks in advance
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by bobin51 View Post
    Thanks in advance
    Most tanks do. If you one doesn't. use a suction pump with a fuel hose attached to pump all the fuel out of it.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Hello bloke. Welcome to the forum.
    8 litres of petrol is not a huge amount. Fill your tank with diesel and motor on. You may notice engine temps become marginally higher.
    Given it is the reserve use it up little by little and there should be no drama.
    Fear not it happens to the brightest and stupidest ( I fall into this category ) of us all!
    Oct 2010
    Old Bar, NSW
    You should be able to siphon most of it out, fill it with diesel and roll on. You probably wont notice a thing.
    Put a full tank of petrol in my Hiace, fortunately realized before it was started. It was siphoned as there is no drain plug, fuel lines flushed filled up and no problem. Being a common rail they dont like petrol.
    Did it at the Taree west servo, two rows of pumps are set out differently and habit grabbed the wrong one on the other side, DOH! Our mechanic said he gets one a week from there because of that.
    Are you from Bobin?
    Macca
  5. #5
    Patrol God Dhuck's Avatar
    Nov 2010
    Crap Weather State
    5 Post(s)
    Welcome to the forum mate.
  6. #6
    Hello and welcome to the forum, transfer the 8ltrs into the main then fill the main up.
    In the meantime enjoy lol
  7. #7
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    G'day mate and welcome to the forum. As others said if you get a full tank of diesel and just burn the petrol in the mix it should be ok. I presume you mean the sub tank, so just run a bit out of the main tank and pump a bit of petrol mix from the sum to the main and top up the sub with diesel. After a couple of top ups the mix will be pretty much all diesel anyway.
  8. #8
    Oct 2015
    Mid North Coast
    petrol in reserve tank
    Was able to use flexable clear Hose to syphon reserve tank YIPPEEE!!!
    Then my problems started could not remove syphon hose. WHY?
    Solution I had to remove tank see attached photos.
    As you try to remove hose from tank it gets trapped on spring loaded cap.
    Thanks for all the replies
    Had to get my better half to type this reply
  9. #9
    Oct 2015
    Mid North Coast
    there is no drain plug on the reserve tank of my 2004 gu
  10. #10
    Oct 2015
    Mid North Coast
    macca not any more
