Page 272 of 570 FirstFirst ... 270271272273274 ... LastLast
Results 2,711 to 2,720 of 5693
  1. #2711
    Quote Originally Posted by Touses View Post
    Just arrived all the way from the USofA.
    This one for New PigAttachment 67505
    This one for Th PigAttachment 67506
    Smilin like the proverbial cat!
    Where you get these from @Touses? Ive been losely thinking of ditching the top mount cooler and opting for w2a.
  2. #2712
    Dec 2015
    WA
    5 Post(s)
    As I understand it, water to air works well on petrol powered road cars where the boost is only in relatively short bursts and the water in the cooler gets some adiabatic cooling between bursts of high boost, they rely a lot on thermal mass.
    Turbo Diesels run boost for long periods of time so they heat up the water & become less efficient.
    Graham
  3. #2713
    Frozenboost
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (14th June 2016)
  5. #2714
    Quote Originally Posted by GeeYou8 View Post
    Graham
    Water to air will hold a more stable temperature on a diesel.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    BigRAWesty (13th June 2016)
  7. #2715
    Advanced caveman21's Avatar
    May 2016
    sandgroper
    Nads kit
    Erg blank plate
    Catch can
    Dawes valve
    Boost control valve
    Egt gauge
    Boost gauge
    Cc intercooler to be ordered at end of the week
    Why do caveman drag there woman by there hair ?
    Cause if you drag them by there feet they fill up with dirt
  8. #2716
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Heya bloke. Yeah out of Frozenboost. ordered 1st June, here 13th but spent more time in OZ than anywhere else en-route.
    Didn't want a top mount cooler so vehicle remains as stock looking as possible. Th Pig has a front mount cooler and it creates probs with airflow when using big boost.
    Also costs a psi or 2 with the 1/2k of plumbing from turbo to inlet. This lot should reduce egt's without boost loss.
    They are a very solid unit the boxier one must weigh between 2-3 kg!
    Both those units and the fillers cost less delivered than a single pwr unit. Very pleased!
  9. The Following 2 Users Say Thank You to Touses For This Useful Post:
    BigRAWesty (14th June 2016), mudski (14th June 2016)
  10. #2717
    Is the bigger one a type 17 1200hp core?
  11. #2718
    Mar 2016
    Childers QLD
    22 Post(s)
    No bloke it's a type 10 only 600 hp, I think. Chose it more for how it would mount as opposed to any hp rating,
    bearing in mind New Pig will only be around 130-140 ponies.
  12. #2719
    Cool. The type 17 is a 1200hp core and same shape as the one pictured. Currently using one on a patrol with around 200hp. In the process of getting a manifold fabricated that incorporates the core into it.
  13. #2720
    Mar 2016
    Childers QLD
    22 Post(s)
    Hey bloke, great minds and all that! Wanted to do same with cores and manifold, had 'designed' the thing in my head but the nay sayers dragged me down
    with cost and manufacture devils. The big argument was cooling, water in, from one end only, the exit of course is not as cool as the entry.
    I reckoned water ingress from both ends and egress from centre. This of course led to arguments re welding/sealing at those ends of the core.
    I backed down on it to get the build bloody well done. I do have a spare manifold tho. Will be giving it further thought as time allows!
