Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: easy way to get tdc on td42
    Mar 2015
    hi guys trying to get tdc on the diesel haveing a bugger of a time doing it on my own what is the easyway to do this over than pulling injectors back out
    Big socket on the crank? Pulling the glow plugs would be easier than injectors if you had too. . .
    Use a 19mm socket on the power steering pump. Tighten the belt if necessary to get it to turn. And make sure its out of gear.
  4. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (11th June 2016), Rossco (11th June 2016)
    177 Post(s)
    Excuse the newbness. Whats tdc? The dead centre ?
    Top dead centre....
    Or to be concluded
  7. The Following User Says Thank You to AB For This Useful Post:
    Hodge (11th June 2016)
    Advanced Dannyboyz's Avatar
    Jan 2016
    Close mate, Top dead center 👍
    Cheers, Danny
    1998 GU wagon - 2.8 out - mighty 4.2 in. Locked front and rear with 4.6 ratios. 4 inch heavy duty coils. Tough dog adjustable shocks. Too much to mention and hopefully more to come.
    Mar 2015
    i actully had a good bit of info to take out the heaters out
  10. #8
    Mar 2015
    so i took the glow plugs out sooooooooo easy so i have done the vaulve clearances just waiting for the battery to charge ...... some silly bugga left the door ajar and the battery droped a bit low so it is on charge go out soon....... hmmmm forgot to put the connection for the glowplugs back on just realised ..... stupid idgit i am lol ok i will go hook it up now
  11. #9
    Mar 2015
    i think i did it wrong it seams it is noisier ....... anyone on the central coast nsw wanna come over and give me some help ??????????
    i got cans of wild turkey lol
  12. #10
    Mar 2015
    OK sympton of the issue rattley top end blows white smoke ....... so im not getting good combustion in one or more of the cylinders ..... im wondering if it may be that the springs are stuffed on the vaulves i dunno ..........help.....
