Results 1 to 10 of 11
Thread: Gu patrol help
    Jun 2015
    Gu patrol help
    Hey everyone I own a 2009 gu patrol crd it has just started making a whining noise when cold not sure if it is exhaust manifold which was replaced 14 months ago just before I bought the car or if it is coming from turbo
    May 2016
    Details of GU?
    What donk?
    There is no legal cure for STUPID!
    May 2016
    Besides the first issue with VVS.. https://www.youtube.com/watch?v=Bt9zSfinwFA
    Looks like stocker with no NADS. Pull vac line off the VNT actuator when running. The VNT should open back up. If it does, then the actuator is fine.
    The noise though sounds like the bearings in the turbo core are shot and the compressor or turbine are hitting the housing. The only real way to know is to pull the exhaust dump off and put finger on back of shaft and feel for free-play.
    That being said, the noise is rev dependent, not matching what would be going on with turbo. Look around the front of the motor for any bearings that maybe gone. For example, the belt tensioner, AC compressor or alternator.
    could also be a split EGR pipe , quite common
    along with a warped manifold
    Also check the clutch pulley on the alternator.
    A long screwdriver or piece of hose may help you
    isolate the noise better
  5. #5
    That's a weird one.. and very sudden..
    All I can suggest is take a long screw driver and hold the tip against the turbo housing and the handle against your upper jaw bone near your ear lobe.. this will resinate noises past the squeal into your ear..
    Is it consists?
    Does it happen only above a certain rpm?
    Does it dissappear when you lift off the throttle at higher rpm?
    Jun 2015
    Only when cold and around 2500rpm but if I remove the vacuum me line to actuator it stops
  7. #7
    Jun 2015
  8. #8
    Ok so as soon as your adding boost it's screaming.
    So have you checked for boost leaks. Soapy water on all the joins?
    May 2016
    Dump pipe off and check shaft play. If it wobbles, she is farked.
    P.S If it is farked, you are putting metal shavings into the motor.
  10. The Following User Says Thank You to LostBenji For This Useful Post:
    BigRAWesty (5th June 2016)
  11. #10
    Jun 2016
    Davidgu
    did you resolve this noise ? I have exactly the same noise coming from mine.
