Page 131 of 220 FirstFirst ... 129130131132133 ... LastLast
Results 1,301 to 1,310 of 2192
Thread: AB's new GQ is finally here
  1. #1301
    Yeah wow. Impressed i am.... if I knew this was happening i would have chucked a sickie on the 40th i had to attend and parked mine right behind AB's Q. Lol.
    Well done to Bene and Mat.
    Top stuff.
    I know. Same here..
    Was very hush hush..
    Could have shown the missus what could have been....
    22 Post(s)
    Bennyboy has some footage actually?
    Yes I do
    https://youtu.be/8zODNOBe68g
    96 GQ coil/Cab
    08 G6eT
  3. The Following 10 Users Say Thank You to Ben-e-boy For This Useful Post:
    AB (31st May 2016), BigRAWesty (1st June 2016), Clunk (31st May 2016), gubigfish (31st May 2016), Hodge (31st May 2016), Kimbo63 (31st May 2016), MB (3rd June 2016), Sherro (16th August 2016), Stropp (31st May 2016), Woof (31st May 2016)
  4. #1303
    Have you driven it again yet? @Rossco have you been in it yet?
    Not yet, I'll take Rossco out this week!
  5. The Following 2 Users Say Thank You to AB For This Useful Post:
    nissannewby (31st May 2016), Rossco (31st May 2016)
  6. #1304
    Bit hard to tell but looks like it Frick'n PULLS!! Spewn about the clutch, that's why we modify or cars, so we can keep spending endless $$ right? ? . . .
  7. The Following 3 Users Say Thank You to Rossco For This Useful Post:
    BigRAWesty (1st June 2016), Sir Roofy (31st May 2016), Winnie (31st May 2016)
  8. #1305
    check the boost gauge hit over 30 at 2000 rpm and then off the dial.
    Still loosing traction in 3rd gear and egt was getting cooler as we went up the hill.
    Amazing results!
    These boys know their ship!
    We'll need to dial it back when we go for a spin...lol
  9. The Following 8 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (1st June 2016), Maxhead (31st May 2016), MudRunnerTD (1st June 2016), Rossco (31st May 2016), Stropp (31st May 2016), Touses (1st June 2016), Winnie (31st May 2016), Woof (31st May 2016)
  10. #1306
    Faarrrrkkkkkk......
    Faarrrrkkkkkk......
    Yep, just took it for a proper drive tonight and it's such a fun car to drive.
    This will be a weapon on Fraser Island in September!
  12. #1308
    Here's some comments that I stole off someone who was there and has a lot of experience with our td42's.
    Fitting a special 12mm produced some very impressive boost response values. The only tune we did was to adjust boost to produce acceptable stable EGT's. We saw 15psi at 1400rpm, 25psi at 1700rpm, 32psi at 1950 rpm and 37psi in at 2100 rpm in a 4th gear pull. Combining these values with the comp map this turbo produces some 38 lbs/min before 1900rpm to produce I would expect a very impressive torque response curve. Until the clutch is fixed and flywheel lightened it is a bit pointless doing a dyno run to see how this turbo effects the torque curve and how torque could be effected by the small turbine above 3000rpm.
  13. The Following 2 Users Say Thank You to AB For This Useful Post:
    MudRunnerTD (3rd June 2016), nissannewby (3rd June 2016)
  14. #1309
    Awsome, have to take us for a spin tomozz. . .
  15. The Following User Says Thank You to Rossco For This Useful Post:
    AB (3rd June 2016)
  16. #1310
    I was going to grab you tonight but it's shitty weather.
    Tomorrow 100% mate!
