Results 21 to 30 of 35
Thread: Best Cranking Battery
    May 2016
    Quote Originally Posted by Rock Trol View Post
    .....snipped...
    Might pay to look at my Turbo & Exhaust wrapping thread.
    There is no legal cure for STUPID!
  2. The Following User Says Thank You to LostBenji For This Useful Post:
    Rock Trol (29th May 2016)
  3. #22
    My Century Overlander was 4 years old when I replaced it with an Optima Yellow Top earlier this year. It was still cranking but was down on cranking capacity after testing. I got a decent deal on the Optima and decided to change it over.
    i hope the Optoma lasts though as a couple of months later my second battery (Deka Intimidator AGM) expanded and died. It was only 3.5 years old. The turbo cooked it. I am a bit nervous now about putting the optima under the hood but it's good to read on this thread that they seem to last. When I removed the battery and tray I went for a short drive so that the car came up to operating temp (86 deg Celsius water temp) and then opened the bonnet. You could really feel the radiant heat from the turbo. On the other side of the engine the crank battery was only warm to the touch. I hope my optima lasts 7 years plus.
    I have a turbo beanie fitted to the turbo on my zd30 Di.
    My Aux battery is a Trojan wet cell 115AH , I have experienced
    less fluid loss since fitting the beanie. Under bonnet temps are much lower now
    especially near the Aux battery
    These are the same batteries the use on the shipping bouys
    in Port Phillip Bay with some solar panels
  5. #23
    Hardcore
    central coast nsw
    It's a idea to increase cooling off time (at shut down) as a beanie will retain much more heat in turbo for longer period.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  6. #24
    @Robo ,I based my decision on thermal dynamics lol
    it will get the heat out faster and I suspect less
    radiant heat as well on near by fittings like intercooler
    etc.
    After a HWY stint Ill idle till the EGTs come down abit and then some.
  7. #25
    Hardcore
    central coast nsw
    etc.
    All good 3dogs, thought I'd just throw it out there in case some didn't know they had that effect on a turbo.
    caking a turbo up isn't cool
  8. The Following User Says Thank You to Robo For This Useful Post:
    threedogs (30th May 2016)
  9. #26
    84 Post(s)
    Has anyone used Bond batteries? Are they any good?
  10. #27
    177 Post(s)
    Never heard of 'em.
  11. #28
    Aug 2014
    Perth
    10 Post(s)
    Ended up getting a Caterpillar 8C3602 710CCA seemed to be the most CCA that would fit the battery tray.
  12. #29
    84 Post(s)
    Never heard of 'em.
    http://www.bondbatteries.com.au/index.php/battery-range
  13. #30
    May 2016
    Never heard of 'em.
    ROFL, I just seen this and thought the same until I remembered seeing a little fold-out sign saying Bond Batteries in front of the dingiest car yards in town.... LOL
