Results 1 to 10 of 14
Thread: Rockit Comp is back on again!
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Hi all.
    The rockit Comp in back on again this coming weekend (28/29 May)
    Held out at janowen hills 4wd park.
    I'm competing in the Yoot,
    Should be a great weekend if anyone wants to head out and watch (may even be a few spots left if you want to drive)
    Cheers!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  2. The Following User Says Thank You to Punderhead For This Useful Post:
    AB (23rd May 2016)
    22 Post(s)
    Bugger......... I have a considerably important function to attend this weekend.
    Who organizes it. I would like to see the rules and what class my ute will fall into. Seeing that and I will definatly enter the next one
    96 GQ coil/Cab
    08 G6eT
    If CDMA rules anything other than STD like lockers etc will see you in Outlaw class
    if you have heaps done, you're up against the big boys Im afraid
    22 Post(s)
    Just found their site. I'd be in the modified. The only thing keeping me out of the locked, up to 35 inch class is the reduction gears and the long arms by the looks of it
    96 GQ coil/Cab
    08 G6eT
    Nov 2011
    Toowoomba, QLD
    http://aneal43.wix.com/rockit-comp-toowoomb
    Here's the site. @Ben-e-boy you could run locked with a penalty for the reduction, you'll be fine with the long arms. It's a fairly relaxed comp, everyone's there for a good time. It's all points based and not timed, so less likely to do damage etc.
    22 Post(s)
    Quote Originally Posted by Punderhead View Post
    Ah righto. I don't really fancy a 75 point penalty. I think next time I'll throw in a stock t-case.
    Its the " Standard spring and diff mounts only" rule that kinda threw me off using the long arms
    96 GQ coil/Cab
    08 G6eT
    Nov 2011
    Toowoomba, QLD
    @ben_e_boy my mate has long arms and pretty sure he didn't get any penalties. They're fairly casual with the comp (that's what makes it great) as for the penalty, my mate who won last time had a 100 point penalty for beadlocks, so if your good it shouldn't worry you.
    22 Post(s)
    Thats good to know
    Lol 100 points they dont mess around with penalties do they
    96 GQ coil/Cab
    08 G6eT
  10. #9
    Nov 2011
    Toowoomba, QLD
    They have changed it a little to make it fairer, in that they give smaller penalties for each track. Last comp my reverse lights were broken, and I lost 15 points per track (1 reverse penalty) fairly sure matty lost the same for his beadlocks (total loss o 105 points actually)
    But as I said, it's fairly relaxed. We ran an extra track last time as there was only a small number of us.
    Just a great weekend really.
    They do have a Facebook page aswell, rockit Toowoomba comp, with more info and a few Piccies.
    Cheers!
  11. The Following 2 Users Say Thank You to Punderhead For This Useful Post:
    Ben-e-boy (24th May 2016), BigRAWesty (25th May 2016)
  12. #10
    Sounds like a wicked comp..
