Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 73
Thread: Can i get a mechanical injector pump for 4.2gq
  1. #61
    Any pictures of the setup??
    To me if your struggling while slow but fine on the highway then is a simple flow issue..
    So do you still have the standard viscous fan plus 3 thermos??
    Advanced landy96's Avatar
    Mar 2016
    Brisbane 1 week. 2nd week home millmerran
    Yes to fans
    Landy 96 cant get photos on here
    Enjoy The Journey
    Dont Be In A Rush To Reach Youre Final Destination
  3. #63
    Quote Originally Posted by landy96 View Post
    Yes to fans
    Your past 25 posts mate you should be right to upload some?
    Hardcore
    central coast nsw
    The fins and thickness can be critical.
    Ok your is thicker but the "FPI" fines per inch, need to be less than standard to allow air flow through it.
    EG--If FPI is large, ( more/same number fins per inch ,not less ) it is like a blanket being put over the rad, reducing airflow.
    A properly matched,for the job thicker rad to fpi ratio build spec can take full advantage of the extra cooling capacity, mis-matched and problems.
    I'm not saying this is the cause just something worth exploring.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  5. #65
    Mar 2016
    Diesel Mechanic said head gasket or cracked head ??? Problem solved ..
    Bloody subscribe scam popups on here keep jaming my phone .
    I have popups blocked on my phone but it doesnt stop these
  6. #66
    Using tapatalk or the forum?
    Sent from my SM-G800Y using Tapatalk
    Hardcore
    central coast nsw
    Is it using water or oil?.
    Whats the compression like?.
  8. #68
    May 2016
    I just read through the whole thread trying to figure WTf are we talking about as the title is for a TD42 pump. Nothing to do with cooking it.....
    I was asking myself the whole way through, have you and or anyone thought to check the radiator for oil or bubbles, Tried checking sump oil for water? The where signs all the way of a crack or leak as well plenty to say that the engine needed a good cooling system clean. The factory cooling on the ZD30's are pretty bloody good, thermos will never beat a engine driven clutch-fan.
  9. #69
    Quote Originally Posted by LostBenji View Post
    Lots of info has been lost between the 2 threads..
    "What once was lost must now be found"
  11. The Following User Says Thank You to the evil twin For This Useful Post:
    BigRAWesty (19th May 2016)
