Page 18 of 25 FirstFirst ... 1617181920 ... LastLast
Results 171 to 180 of 241
Thread: Now The Drivers Door Wont Open!!!
  1. #171
    Feb 2011
    Shed
    45 Post(s)
    ST's are electric and the DX is just key and linkages I think.
    So the mighty DX has its demons as well.
    Yes but the mechanism to lock is the same. Its not the actuation whether elec or manual of the lock thats the problem. Its the bastard internal workings that simply wear out
  2. The Following User Says Thank You to growler2058 For This Useful Post:
    BigRAWesty (8th May 2016)
  3. #172
    Feb 2011
    Shed
    45 Post(s)
    [QUOTE=Clunk;675645]are you sure its not an issue with the locking rod linkage type thingy as opposed to the new plastic thing you bought............................
    oh and by the way
    Has the linkage or door handle stretched or bent in any way, causing the mechanism not to move enough to operate?
    No, even disconnecting all linkages the locking part doesnt move freely to lock
  4. #173
    Is there anyway you can see,,,,,,,, to prevent it wearing out,
    or just one of the DX quirks,? LOL
    EG hold the linkage up with a cable tie etc,,,,,,,,,,,,,
  5. #174
    Feb 2011
    Shed
    45 Post(s)
    No there isnt.
    It can affect ALL GU's. The part number is the same for ALL GU variants
  6. The Following User Says Thank You to growler2058 For This Useful Post:
    threedogs (8th May 2016)
  7. #175
    Ok so the doors open, now other than the $300 lock what other costs did you manage
    .eg 1 case of Johnnie Walker, pkt aspirin, 6 x bandaids
  8. #176
    Feb 2011
    Shed
    45 Post(s)
    I'm up for another door trim. And still need another new lock as this one has a fault locking now
    Personal costs are bit of bark off me knuckles an amount of mental anguish
    Positives I can flex my back due to the recent forced yoga
  9. #177
    Feb 2011
    Shed
    45 Post(s)
    Removed the lock in its entirety this morning to make sure I wasn't having a brain fart moment or two
    Small vid below of the difference in movement between the old and the new. It's fair to judge that the old one has a wear factor but not to the extent that it has 75% more travel
  10. The Following User Says Thank You to growler2058 For This Useful Post:
    Touses (8th May 2016)
  11. #178
    84 Post(s)
    Maybe someone assembled it wrongly. I bought a brand new fuel sender for a Falcon once and it went from full to 1/2 back to full as some idiot had crimped both ends to the earth.
    Try and get the supplier to email you a vid of another new assembly's movement.
  12. The Following User Says Thank You to mudnut For This Useful Post:
    growler2058 (8th May 2016)
  13. #179
    Feb 2011
    Shed
    45 Post(s)
    I'll be ringing them tomorrow to discuss my options
  14. The Following User Says Thank You to growler2058 For This Useful Post:
    Chubba (8th May 2016)
  15. #180
    Fair bit of movement in that lower one,
    Hopefully Monday will sort it all out lol
