Page 648 of 1057 FirstFirst ... 646647648649650 ... LastLast
Results 6,471 to 6,480 of 10561
  1. #6471
    Started the exhaust lol.. couldn't help myself..
    So far so good
  2. The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
    jay see (6th May 2016), mudnut (6th May 2016), Roosim (8th May 2016)
  3. #6472
    82 Post(s)
    Finally got the EGR pipe fitted to the headers.
  4. #6473
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    So far so good
    How many times did you soak the studs? Good luck!!
  5. #6474
    Ummmmmm. .. twice..
    Actually most of em were loose.. which isn't good..
    In 3 hours I've removed pipe work around the turbo, the catch setup, removed actuator to remove the heat shield, remived flex section of exhaust, old dump pipe, tried fitting new dump pipe, had to remove sway bar, fitted dump pipe and so far all good.
    Refitted actuator and sway bar..
    So tomorrow it should all be smooth sailing..
  7. The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
    Bacho86 (6th May 2016), Hodge (6th May 2016), jay see (6th May 2016)
  8. #6476
    176 Post(s)
    Well done bloke. So far you're way ahead of where I was at that stage. I can't recall removing the sway bar though .
    Mar 2011
    14 Post(s)
    Ummmmmm. .. twice..
    No I wouldn't think so...
    Good work, sounds like it's all going to plan then !! When you going to attack the heat shield?
  10. #6478
    It's out..
    Was a carnt.. all the heater hoses over the top of it I have to remove the actuator to get it out..
    That's what I've achieved this arvo..
    Tomorrow I reinstall the intake and finish the rest of the exhaust fit out..
    Dump pipe fit perfectly..
  11. The Following User Says Thank You to BigRAWesty For This Useful Post:
    jay see (7th May 2016)
  12. #6479
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    Mounted up the roof top light bar. Now the fun job of wiring it in..
    '96 GQ TD42t
  13. The Following 3 Users Say Thank You to Chappy For This Useful Post:
    BigRAWesty (6th May 2016), mudski (7th May 2016), threedogs (7th May 2016)
  14. #6480
    Mar 2011
    14 Post(s)
    What did you do to your Patrol today!
    Put the mud tyres on ready for next weekends high country trip!
