Quote Originally Posted by Dan02 View Post
mate i hope it wasn't anywhere near overheating,,, car empty and due to the wobble only doing 80km so bugger all load and its way out of summer.
in that case, sounds like a loose connection on the Air Con pump
have a look at the wiring, it may be old and just need a clean up on the terminal
if not that, then check behind the dash for loose wiring -
has the radio been changed? maybe didnt put the earth to a good spot
Nissan's are bad for earths - really bad
intermittent faults are usually an earth problem
