Ok. New CV is in. All went well on that part. CV was quite notchy so thats done.
The knocking is still there though.
I got Jonathan to climb under while i kick the front of the rh wheel.
Seems to be coming from where the drop box is. All the bolts in that area are tight.
When i climbed under and had the wife kicking the wheel, if i put my hand on the floor and applied some pressure, not alot, the noise would go away. Se as if i push on the side step.
So i might have to remove the carpet and check the floor for cracks or anything out of the ordinary. Plus ill remove the drop box and inspect it and the mounting area.
Bloody strange this is. I have to crawl over a speed hump so it wont make the noise. Lhs is fine. No noise.
Getting there. Lol.
