Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 44
Thread: Stuck open thermostat.
  1. #31
    So I'm really unsure now..
    Had car up to 87oC tonight and now had it idling for about 10 mins and it's only dropped to 84oC...
    It's currently 11.5oC outside..
    Maybe it's in its way out..
    Nothing wrong with those numbers at all.
    Any cooling system will recover when left to idle uness you have a fan issue
    Wheres the Patrol from again as in History
  2. #32
    Ex cfs from baccasmarsh..
    Yea I realize it'll come down. The other day it dropped from mid 80's to low 70's
    So it should have an 83 degree fitted, goodluck pulling it out.
    Remove the shroud, plastic fan and alternator.
    Thats if its similar to mine
    BigRAWesty (21st April 2016)
  5. #34
    Yep I'd say it is....
    Thats the standard thermo for Aus.. the 78 is Gulf spec and the 88 is for the cold bits of the planet
  7. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (21st April 2016), MB (22nd April 2016)
  8. #36
    Yea I've had a look at the zd30 thermostat location. ...
    It's not pretty lol
    It's not that bad, but small hand help.
  9. The Following User Says Thank You to jay see For This Useful Post:
    threedogs (22nd April 2016)
  10. #37
    Bacchus Marsh is only up the road from me
    so a 83 thermostat would be Ok, just a word of
    warning ,,,,be very carefull with the shroud its
    very brittle, you only need to remove the bottom
    bit and the top half. That will give you plenty of
    room to access the thermostat. Just lay a few blankets
    over the bull bar and the top of the radiator,
    beware that overflow spout on top of the radiator to
  11. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (22nd April 2016)
  12. #38
    So did you try what I said?
  13. The Following User Says Thank You to Clunk For This Useful Post:
  14. #39
    I did.. and it feels soft but I'm not sure what the zd feels like as it has 2 feeds to the top tank.. one from the engine and one from the radiator..
    I dont know how different they are to TB42 or TD42, but Im talking about the large pipe that goes from the radiator to the thermostat housing.
