Page 12 of 14 FirstFirst ... 1011121314 LastLast
Results 111 to 120 of 131
Thread: Westy's GU
  1. #111
    Got more flow than this bloke..
    What a setup! !!
    What a setup! !!
    Thats a full air suspension set it eh ?
  3. The Following User Says Thank You to threedogs For This Useful Post:
    BigRAWesty (5th March 2016)
  4. #113
    Yep. Full air and hide control
    This is the pump and tank I had in my other 4x4
    http://www.ebay.com.au/itm/Boss-Air-...IAAOSwMmBVlOpM
    Dont forget a non return valve otherwise
    the system will leak back past the piston
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #115
    So rhino rack had 25% off roof bars in stock and just my luck all in stock..
    $70 ish bucks off so happy days..
    All black aero bars with gutter mounts all rated for 225kg...
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Hodge (13th March 2016)
  9. #116
    Mar 2016
    Just read through this thread. Again very nice pick up, and good score on those roof bars!
  10. The Following User Says Thank You to 88WAH For This Useful Post:
    BigRAWesty (14th March 2016)
  11. #117
    @ Kallen seeing you have the rear inner panels off, IYO would
    you think those rear seat belts would fit the front driver/passenger
    ones
  12. #118
    ones
    No idea mate. I'd say they are shorter..
    So winch is a few steps closer to done..
    We got the bar off and re positioned the gearbox to a much nicer position and fitted the solinode and wiring in..
    We also fitted the snorkle..
    God dam what a pain..
    5 hours!!!!!
    I know why the charge $300+ to install them...
    So I have also fitted up the awning with an led light strip down the mount to a cig socket to plug into the rear...
    Cant wait to use it all..
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Kimbo63 (17th April 2016)
  15. #120
    Patrol Guru Rocket55's Avatar
    Sydney
    Nice job mate, looks great. How'd you go squeezing in half a tube of sikaflex to seal the airbox to the inner guard.
    Cheers Rod
    My Build 2005 TD42TI
