Page 11 of 44 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 434
Thread: Threedogs motor thread
  1. #101
    Quote Originally Posted by trekster View Post
    Sounds like you have the same problem I recently had except I didn't stick gunky sh*t into my cooling system, my gu8 would run hot, few times got up to 110-115c, Wasn't losing coolant, but would pressurise the system after driving and not let the coolant back into the system and it would get stuck in the overflow tank..
    The solution? A brand new radiator, Mine was over 70% blocked and this is only a 3 and a bit year old car mind you, Cooling specialist said they should be flushed every year or they get build up in them and clog up. Since I changed to new radiator, Running temp 86-92c with 92 being full noise and 600+ egt up a hill......
    Mine also doesn't run a front ac fan.
    This...... pull the rad, or i can do it. And either get it checked, will cost you $$$, for the check. Then they will either say, it fubar, more $$$, or you just bite the bullet and replace it anyway. Still $$$, but less than a check and new rad.
    That is. If its just cooling issue you have. Not something more sinister. Then you will no choice but to get a professional to take it further. Compression and sniff test would be the first i would be doing.
    Clunk (10th April 2016)
  3. #102
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    @ Mudski if you need a hand ill come down let me know what day ??
  4. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Hodge (11th April 2016)
  5. #103
    177 Post(s)
    Quote Originally Posted by roofy View Post
    Yeah same if & when you go if I'm free I'll come help. Just let us know.
    Ill ring the guys from Bundoora radiators as the warranty may be better
    Ok warranty was 2 yrs for $290ish, Ill get my son to pick that up.
    Ill pick up a trade order to further reduce that price?
  7. #105
    If you order it for Wednesday I can pick it up on my way across to you. Make sure you specify auto trans too.
    Roofy and Hodge. Thanks for the offers but it will be myself and JaySee there on Wednesday. Its really only a one man job for this....
  8. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (11th April 2016), Sir Roofy (11th April 2016)
  9. #106
    177 Post(s)
    No dramas. I got work Tuesday night and I'm off Wednesday so if you still need a hand im free to tag along.
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    You guys are awesome. Mark you are a great bloke fresh off sorting out roofy and your into another assist
    Lucus30's 1999 GU ST TB45E
  11. The Following 5 Users Say Thank You to lucus30 For This Useful Post:
    Bacho86 (11th April 2016), Kimbo63 (11th April 2016), mudski (11th April 2016), Sir Roofy (11th April 2016), TPC (12th April 2016)
  12. #108
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    X2 on that mark the mudskipper ledgen
  13. The Following User Says Thank You to Kimbo63 For This Useful Post:
  14. #109
    Thanks. I try to help out where i can. Even if it will only be a couple of hours. My weekends i have been told by the boss are to be spent at home for a while. Lol.
    She doesnt realise theres a long weekend coming up. She's not gonna be happy.
    I do hope for Johns sake its just in need of a cooling overhaul.
  15. The Following User Says Thank You to mudski For This Useful Post:
  16. #110
    Mate your welcome to come along and just talk chit, or pass a spanner.
    We need Rossco though really. Hes got long skinny fingers. Great for accessing bolts in tight spots. Lol. I got short kranskys for fingers.
  17. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Hodge (11th April 2016), Rossco (11th April 2016)
