Page 10 of 44 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 434
Thread: Threedogs motor thread
  1. #91
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Time to liquidate some assets, you seem to have a shed full of treasures.
    Parting with stuff collected might not be easy.
    When times are tough, tough decisions need to be made
    \\Get onto it TD
    ________________________
    ______ 2017 D-Max _______
  2. #92
    And stop buying shit off ebay...... every little bit helps
  3. The Following User Says Thank You to Clunk For This Useful Post:
    firm351 (10th April 2016)
  4. #93
    \\Get onto it TD
    Common guys back off a bit yea..
    let's find out an issue before dollars are sought..
    It's no one's place except Johns to decide on what gets spent and where..
  5. The Following 3 Users Say Thank You to BigRAWesty For This Useful Post:
    Bigcol (10th April 2016), Irish (11th April 2016), jay see (10th April 2016)
  6. #94
    @ mark you think your light will reach the thermostat??
    Just PM a time Ill make sure motor is cold
    The lead is maybe 500mm long. I reckon it will reach. Ill get in touch mate.
    BigRAWesty (10th April 2016)
  8. #95
    Quote Originally Posted by paulyg View Post
    I did my water pump last year, the pump was fine but the viscus hub was shot, the hub and pump are not available separately on the DI motors.
    when I turned the fan, I could not feel any difference between hot or cold.
    It was not to difficult, to change, but a pita to get to some of the bolts.
    The electric fan on the air-conditioning condenser on my truck cycles on and off, depending on the temp.
    I do not think the hub is your problem, my temp would go up slowly, and it never boiled.
    Thanks Paul. So atleast its doable if need be then.
  10. #96
    I think its worth a Crack. . You'll at least see what's floating around in there and general condition of it all even if you can't reach the thermostat..
    how small is the head? Is it able to check radiator cores?
    Hey oh wise one, yes you're right....not havin a crack, just stating the obvious, it's what I do when times are tough, I dont spend money on stuff and sell shit I don't really need....... you do what's needed to get shit done
  12. The Following 3 Users Say Thank You to Clunk For This Useful Post:
    Bloodyaussie (10th April 2016), macca (11th April 2016), Sir Roofy (11th April 2016)
  13. #98
    The head is a BIC pen size in diameter. We could stick it in the rad and have a look. Its only a cheap camera but it works.
  14. The Following User Says Thank You to mudski For This Useful Post:
  15. #99
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Sounds like you have the same problem I recently had except I didn't stick gunky sh*t into my cooling system, my gu8 would run hot, few times got up to 110-115c, Wasn't losing coolant, but would pressurise the system after driving and not let the coolant back into the system and it would get stuck in the overflow tank..
    The solution? A brand new radiator, Mine was over 70% blocked and this is only a 3 and a bit year old car mind you, Cooling specialist said they should be flushed every year or they get build up in them and clog up. Since I changed to new radiator, Running temp 86-92c with 92 being full noise and 600+ egt up a hill......
    Mine also doesn't run a front ac fan.
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
  16. The Following 3 Users Say Thank You to trekster For This Useful Post:
    Clunk (10th April 2016), Hodge (10th April 2016), mudski (10th April 2016)
  17. #100
    I'm thinking it it has blocked the thermostat it's possible it's blocked some cores too..
    Worth a look if ya can imo..
