Results 1 to 7 of 7
Thread: Dawes and needle valve settings/wind noise
    Advanced landy96's Avatar
    Mar 2016
    Brisbane 1 week. 2nd week home millmerran
    Hi landy 96 here..
    Trying to set dawes and needle valve on zd30 2002 cant get over 10 boost just looses all power and makes a loud wind noise gets louder the further i turn it . I tried setting needle as described on forum ?? Does anybody near brisbane southside know how to set these please asked a couple of local mechanics and they both said we take them out .
    Assuming you have the plumbing all correct heres what you do.
    1. Wind the needle valve(blue cap) right in.
    2. Wind the Dawes in maybe until 1/4 of the thread is showing. (Starting point)
    3. Start car up.
    4. Open the needle valve until the rod on the actuator drops maybe 10mm. This part varies from car to car. You may need to close it off, or open it a bit more.
    5. Take the car for a spin and see what max boost you get.
    6. If the boost rises really slow and you have not much acceleration, close off the needle valve a little more. When I say little, I mean a little. 1/8th of a turn. Too much adjustment at one time you will just lose yourself in the adjustment process. Do this until your boost rises faster.
    7. If the boost rises real fast, you open the needle valve up a little to slow the boost down. Ideally, you want the boost to hit the max boost level set by you quickly, but not go past it and then settle back down. But sometimes tihs is not achievable, so don't get too tied up in this if you cant. Mine used to bounce way past by about 6psi and then settle, but thats how I liked it.
    8. Aim for about 16psi as a starting point for max boost. And no less than 10psi at 100k's.
    9. To adjust the 100k boost, this is done via the needle valve. by closing the needle valve it will make your boost rise faster, but at the same time, increase the 100k's boost level.
    10. Remember the max boost level is relative to the 100k's boost. The higher the max boost you go, you need to raise the 100k's boost too. Otherwise your boost wise rise too slow and the car will run like poo.
    When I had my ZD30, I was running 25psi max boost and 18psi at 100k's. Which meant the needle valve was pretty much totally shut. I tried to lower it but the turbo just wouldn't perform...
    Hope this helps.
    Cheers.
    Mark.
    landy96 (5th April 2016)
    Mar 2016
    Thanks mark. Do you have any idea what the wind noise might be it gets very loud
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    Sounds like you have a leak in the system somewhere. Most likely the IC. Check that all hoses fit correctly and clamps are tight.
  6. The Following User Says Thank You to BillsGU For This Useful Post:
    If you still have the original intercooler
    chances are its oily there fore leaking.
    dont worry they all do, You'll need to source
    a fully tig welded one, Diesel Smart do one
    at a very good price IMO lol
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #6
    Quote Originally Posted by landy96 View Post
    As Bill and TD have said its quite possible that your intercooler is leaking. If it is, there is no way you will be able to raise the boost level via the Dawes. As all the extra boost pressure you are trying to put in will simply leak out. If the intercooler is leaking, oil deposits on the cooler is a good give away that it is leaking.
    If the cooler is good. Check all the hoses and clamps. Might be possible that the egr pipe is leaking too, but I don't think this would stop you achieving boost though...
  11. #7
    Mar 2016
    Thank you all very much.i found one of the hoses leaking and tightened that. And iset the dawes and needle valve the way mudski described and its runing nice now .cheers.
