Page 73 of 101 FirstFirst ... 7172737475 ... LastLast
Results 721 to 730 of 1003
Thread: Hodge's new 4.2
  1. #721
    177 Post(s)
    Fixed it.
    Dont forget things like power steering and brake fluid .
    Sorry bud lol. Just used to it as one of my close mates is Matt with dual T's.
    Power steering never even crossed my mind. Noted.
    Clutch fluid will get done when they swap my clutch over in a few weeks time hopefully. Brake fluid I don't dare touch, to be honest... It's the stuff that brings these 2.8 tonnes to a halt lol.
    Quick one for ya... Does engine oil need to be dropped when water pump is being replaced? I guess not, since it'll be siting in the sump. But thought I'd ask. I'll be doing that too this weekend, would hate to do it only for them to re-do it when they do the pump.
  2. The Following User Says Thank You to Hodge For This Useful Post:
    nissannewby (28th March 2016)
  3. #722
    No only coolant dropped to do the water pump.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
    Hodge (28th March 2016)
  5. #723
    Patrol Guru Rocket55's Avatar
    Sydney
    This was a supercheap cheap one. I guess I'll have to go and grab a new one. .. Mind you I did put some unordinary forces on it no wonder it snapped .
    This is the one I have and I haven't broken it yet and that's using 4' of pipe on 3/4 gear undoing suspension bolts etc. so it's had a pretty hard time.
    Cheers Rod
    My Build 2005 TD42TI
  6. The Following User Says Thank You to Rocket55 For This Useful Post:
  7. #724
    177 Post(s)
    Quote Originally Posted by Rocket55 View Post
    That's the one I'll be getting now! And below is the one I've had so far that broke... Steel frame one is only $10 more.
    Rocket55 (28th March 2016)
  9. #725
    Hey Eric just catching up on your thread. Are you doing a big 100,000km service? Is your clutch done at 100,000kms!!!! Wow! My GUIV has 260,000kms on it now, I bought it at 94,000. Still has the original Clutch. Only in the last couple of months have I thought it might be coming to an end. 100k seems crazy!! Be interested to see what it looks like when it comes out??
    How much are they charging you to do the clutch? What was the TT Clutch worth?
  10. #726
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    All rotated, I'll stick to Matt's rotation every 4-5k from now. Front hubs have severe corrosion, once again shows the car has been dipped in the ocean plenty... Went out and got the rest of the oils but will run out of time today. Next weekend, which will also be time to re-flush the rear diff.
    Whats the yellow thing sitting under your coils?
    Lucus30's 1999 GU ST TB45E
  11. #727
    Its like a neoprhrene hat/base/ spacer they come in many sizes I have the 15mm ones
    Im yet to fit mine yet, might see when the northern boys are free if they could give me a hand .
    @ Eric hope non of this corrosion will cause any electric problems later on.?
    Ive seen looms with salt damage 700mm plus into the loom
  12. #728
    Sep 2013
    16 Post(s)
    ok thanks 3ds. What is the purpose of it? Its not a coil spacer is it?
  13. #729
    177 Post(s)
    I hope not mate. That would piss me off.
    And whenever you want to fit the spacers let me know, will give you a hand.
    177 Post(s)
    As TD said mate it just to help raise the front a little bit ... They come in 10mm and onwards in sizes...
