Results 11 to 20 of 41
Thread: Fitting a CAV filter to TDi42
    couldn't be bothered culling all the rest of the quote out but here is the CAV filter and the move i made on the GQ.
    Ok been busy under the hood over the last month. I am getting a few things sorted while it's parked up. I am getting it ready for a bigger airbox and hopefully a stainless snorkel through the bonnet at some point.
    I have moved the Fuel Primer pump and the vacuum tank to the drivers side and stripped a heap of other crap off the fire wall. I removed the clutch bleed hose and tube and replace the hose and block to allow for the removal of the extra bleed.
    This is a Big Job and will take some nutting out to put Humpty Dumpty back together again but it's getting there
    Before.
    Attachment 52115Attachment 52116
    Fuel primer now attached to drivers side battery tray just above the fuel pump. The copper fuel pines across the fire wall are gone.
    Attachment 52118Attachment 52119Attachment 52120
    I relocated the vacuum tank and used the copper tube as the primary supply to the tank rather than from the tank just to the clutch
    Attachment 52121Attachment 52122
    Getting there
    Attachment 52123Attachment 52124
    Stripped out the clutch bleed valve as it's pointless. Phill at the 4WD Shed sells a replacement hose and block without the bleed for the win.
    Attachment 52125
    Removed the redundant dual battery solenoid and wiring and pulled back a few wires that were no longer being used.
    I am going to move the fuse block and have to remount it and sort out al the accessories that were going to the second battery that no longer exists. A bit to do yet but it's coming together
    From this
    Attachment 52115
    To this
    Attachment 52126
    To this
    Attachment 52127Attachment 52128Attachment 52129Attachment 52130
    Coming together.
    Cuppa (27th March 2016)
  3. #12
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    If you're fitting it in series with the factory filter, use the same size barbs and fuel hose.
    I'm also thinking of adding one of those and I currently have a lift pump which is recommended if you're running 2 filters otherwise the pump will work harder to suck through both filters
    John
  4. #13
    Oct 2010
    Old Bar, NSW
    Cuppa used a piece of angle aluminium to mount the CAV. A small piece is bolted to the flat that you see in the photo (2 bolts visible)
    Also fitted an outboard motor primer in the line from the tank to push fuel into the filters.
    On the OEM filter the hose on the firewall side is from the tank, that has been extended (see brass joiner) through the bulb primer to the CAV then back from the CAV to the OEM filter.
    If things go all wobbly the line from the tank can be put back in its original spot and away we go... I hope!
    You might find this interesting too,
    http://www.nissanpatrol.com.au/forum...ters-yes-or-no
    Macca
  5. #14
    176 Post(s)
    Thanks Darren & Matt, both very helpful ............ & I'll buy a spare bowl!
    I guess it's safe to assume that the 45 litres per hour max flow rate that the 296 filter has, in conjunction wth the factory filter works ok with the pump I have.
  6. #15
    Morayfield, QLD
    I thought the bowls were made from a polycarbonate now so pretty hard to break.
    Your pump will work harder as the filters start to clog. A lift pump also resolves all the priming issues.
    John
  7. #16
    Makes so much more sense!! My spare is also glass but again at least 10 years old.
  8. #17
    Oct 2010
    Old Bar, NSW
    What , where, how... can you give us a bit more info on the lift pump set up you have.
    The set up I have has been on my Patrol for 6 years and 110000 klm, its working fine. Not sure now ???
    Macca
  9. #18
    Oct 2010
    Old Bar, NSW
    Might be a bit clearer Cuppa.
    Macca
  10. #19
    176 Post(s)
    Thanks Macca, all clear now. I'll be doing as you've done, except will utilise some 3mm ally angle I have. Much better than going over to the other side of the engine bay. Ordered all the bits & pieces online this arvo. Now have to wait for the postman.
    For anyone else considering fitting one of these filters as a 'pre-filter' ........ my main concern had been around the potential for a saga with priming each time the filter was replaced, but utilising a priming bulb as Macca has done will deal with that very well. Be aware that whilst there are plenty of cheap priming bulbs available, not all are suitable for for use with diesel.
    I also read elsewhere where someone had written with certainty that the fuel lines on the TD42 are 10mm. Just to be sure I eased the hose part way off the factory filter housing on mine & measured the hose tail diameter. It was 8mm.
  11. #20
    Took a couple of pics earlier and just getting back to the forum now.. Looking at the way you mounted it Macca I reckon there would only be maybe 500mm of extra hose mounting across the bay. Either way is all good though.
    Here is the mounting position I used on the GUIV.
    macca (29th March 2016)
