Page 117 of 220 FirstFirst ... 115116117118119 ... LastLast
Results 1,161 to 1,170 of 2192
Thread: AB's new GQ is finally here
  1. #1161
    Mate i have lockers front and rear ... how about you princess! !!!
    He has wealth, happiness, stability and content in his life and lots of it
  2. The Following User Says Thank You to AB For This Useful Post:
    Sprock (1st April 2016)
  3. #1162
    And a GQ Patrol sized hole in his heart that needs to be filled.
  4. The Following 5 Users Say Thank You to Winnie For This Useful Post:
    AB (27th March 2016), Bloodyaussie (27th March 2016), Clunk (27th March 2016), MudRunnerTD (27th March 2016), Sprock (1st April 2016)
  5. #1163
    FAR Out man!!
    Shoulda just bought a CRD and been done with it
    Can you even get in yours yet?
  6. The Following 5 Users Say Thank You to nissannewby For This Useful Post:
    AB (27th March 2016), Clunk (27th March 2016), growler2058 (28th March 2016), MudRunnerTD (27th March 2016), Rossco (27th March 2016)
  7. #1164
    Yeah he does miss his old gq that's for sure!
    When I met him at Loveday he was a happy young fella, now....
  8. The Following User Says Thank You to AB For This Useful Post:
  9. #1165
    It's doing wonders to his enforced weight loss program
  10. The Following User Says Thank You to Clunk For This Useful Post:
  11. #1166
    Feb 2011
    Shed
    45 Post(s)
    And you need all the help you can get!
  12. #1167
    Feb 2011
    Shed
    45 Post(s)
    I'm top of my yoga class now
  13. #1168
    Feb 2011
    Shed
    45 Post(s)
    Yesssssssss
    Just a little bit awkwardly
  14. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    MudRunnerTD (28th March 2016), Rossco (28th March 2016)
  15. #1169
    Finally got time to jump back on the gq.
    Turbo finally bolted up!
    It's a tight fit, slight panel beating to fit the wastegate in.
    Just need some more 4" clamps, m8 studs, T piece and hose for the recirculation valve, oil drain fitting and I think I'm ready to connect everything up...Yay!
    But does it even SPOOL!! Make it work bud..
  16. #1170
    It will. It should be better than the ht18 with the standard pump andy has. But once the 12mm goes on it will be incredible. If all other supporting mods are done this turbo can support nearly 200rwkw
  17. The Following 3 Users Say Thank You to nissannewby For This Useful Post:
    MudRunnerTD (28th March 2016), Rossco (28th March 2016), Winnie (28th March 2016)
