Righto so I've got a Scangauge 2 ordered. If I get my boost/pyro gauges, can I hook up the pyro to my standard exhaust if I'm keeping it for the time being? Would it just be a case of drilling and welding a nut on?
I also did a bit of an external inspection of the standard IC. There is definately some oily black residue coming out where the crimping join is on one end & underneath. The leaking doesn't seem huge but still evident. How urgent is replacing it?
After looking into a replacement IC I read about tube & Fin or bar & plate cores. Are either of these better or worse than the other? I am only after a standard size replacement as I don't have the $1200 to only throw at an upgrade. Any advice on what I should be looking for?
