Page 241 of 570 FirstFirst ... 239240241242243 ... LastLast
Results 2,401 to 2,410 of 5693
  1. #2401
    a o ring ... damn they aren't cheap
    I hope your joking....
  2. #2402
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Just put the money down on a new set of rubbers and rims. Km2's on steelies.
  3. The Following 2 Users Say Thank You to Covo71 For This Useful Post:
    BigRAWesty (9th March 2016), megatexture (10th March 2016)
  4. #2403
    brisbane
    Quote Originally Posted by Covo71 View Post
    What size and how much a corner if you don't mind me asking
  5. #2404
    Advanced dave97's Avatar
    Jan 2015
    I bought a wiring loom, new washer bottle and washer motors, and series 1 lights so people stop almost running up my back end when they tail gate me.
  6. #2405
    50A solid state relay
    90-110 psi cut off switch
    50 degree thermostat switch.
    Small barn door extension bracket..
    Next is a compressor switch and led light bar switch.
    I went for red switches mainly as they dont glare at night and very easy
    on the eyes
  8. #2407
    Measured with a clamp metre it wasn't quite 10amp some thing like 9.7 but close enough for me.
    Even 8.5 amps I'd be stoked with. Fridge draws about 4 so even if it was running constantly id be in front
    I do have another 120w foldable if i ever needed more juice
    Clamp Meters will often give some 'unusual' readings on low current DC.
    Budget for a max of 8 amps and you won't be dissapointed
    I have a 100 Watt blanket and it reliably produces 5 amps without getting too anal about angles and moving it every 30 minutes
  9. #2408
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Clamp Meters will give some 'unusual' readings on low current DC.
    Yeah I know they aren't perfect... However it is a good fluke meter so I'd hope it would be as accurate as you could get for a clamp meter
    Lucus30's 1999 GU ST TB45E
  10. #2409
    Jul 2015
    Camden NSW
    6 Post(s)
    Bought a "winch in / winch out" carling style switch for "in-cabin" winch control. Not going to wire it up the traditional way. Going to wire it to a warn winch plug and only plug it in when required.
    Bazza
  11. #2410
    Oct 2010
    Old Bar, NSW
    Bought the 150w solar blanket too. Lying on my bonnet the other day I was getting 10 amp gotta be happy with that
    Got it today, had an old battery to try and recharge so hooked it up with the blanket flat on the drive at 2.00 pm saw 6 amps on my clip meter.
    The high voltage light was on which means the battery if already fully charged, that is not the case. It also doesn't work at all on the Redarc BCDC solar input either.
    Give it good test over the weekend and compare it to the folding 120watt panel I have.
    Macca
  12. The Following 2 Users Say Thank You to macca For This Useful Post:
    BigRAWesty (10th March 2016), megatexture (10th March 2016)
