Page 240 of 570 FirstFirst ... 238239240241242 ... LastLast
Results 2,391 to 2,400 of 5698
  1. #2391
    Oct 2010
    Old Bar, NSW
    Bought the 150w solar blanket too. Lying on my bonnet the other day I was getting 10 amp gotta be happy with that
    Good to hear, will pick mine up in the next couple of days
    Macca
  2. #2392
    Do you have a link ??
    I have some spare solar panels here I'm thinking of bolting to the roof rack
    not 100% sure yet, not happy having to park the Patrol in the sun for full
    benefit
  3. #2393
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    benefit
    Here you go mate
    http://www.supercheapauto.com.au/onl...ecommendations
    Lucus30's 1999 GU ST TB45E
  4. The Following User Says Thank You to lucus30 For This Useful Post:
    threedogs (9th March 2016)
  5. #2394
    brisbane
    Two powercrank 105ah Agm batteries 260 ea
  6. The Following User Says Thank You to megatexture For This Useful Post:
  7. #2395
    brisbane
    Did you have something else supplying power also cos I don't see how those panels can put out 10amps, 8.5 at the most.
    and they are from sca after all
  8. #2396
    178 Post(s)
    Quote Originally Posted by megatexture View Post
    I use the rough & ready 70% calculation to estimate a panel’s output when mounted flat or close to.
    Wattage of panel divided by nominal voltage & multiplied by 70%.
    In this instance 150/12 = 12.5 12.5 x70% = 8.75A ..... so I’d agree with MT’s estimate of 8.5amps.
    However - brand new panels often perform over spec & ‘settle down to more conservative figures after a little regular use. In addition a bright but cool day, particularly if close to large bodies of water (reflection) can also push output above specs. These are the exception rather than the rule though. It is also possible that this new solar blanket has a higher efficiency that
    most panels available, but I too wouldn’t expect that from SCA products.
    So Lucas, when, a bit further down the track, your panel’s output is more like MT expected - don’t be disappointed - it’s normal.
  9. #2397
    Any updates on your Patrol>
  10. #2398
    Sep 2013
    16 Post(s)
    Measured with a clamp metre it wasn't quite 10amp some thing like 9.7 but close enough for me.
    Even 8.5 amps I'd be stoked with. Fridge draws about 4 so even if it was running constantly id be in front
    I do have another 120w foldable if i ever needed more juice
  11. #2399
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    a o ring ... damn they aren't cheap
  12. #2400
    brisbane
    Yep she's going good bar a transfer case seal leak and antenna motor died and front end bushes majorly flogged out.
    Though not doing damage yet so not high on my ever growing list to do unfortunately
  13. The Following User Says Thank You to megatexture For This Useful Post:
    BigRAWesty (9th March 2016)
