Results 1 to 10 of 15
Thread: Air pressure in air bag suspension
Threaded View
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Nobby View Post
    Sorry for being ignorant but what is "Axle Articulation"?
    Is it good or bad to be reduced?
    Axle articulation also called flex in simple terminology is the travel of the axle from maximum stretch to minimum compression if that makes sense, how far each wheel can travel up and down. This is the reason a lot of us do suspension upgrades with a lift it gives more travel over standard, so with an air bag i would assume you dont get as much upward travel because the bag is there and stops maximum compression
  2. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    Nobby (15th April 2011), Silver (7th August 2011)
