Results 1 to 6 of 6
Thread: whats this king pin shim preload marlarky?
Threaded View
  1. #4
    Aug 2015
    Correct. The only way to adjust the pre-load is by putting in different thickness shims. So, to do this correctly, you'll likely need several different sizes on hand before you start. Patrolapart has some sizes, but I ordered four (2 per side - top and bottom, 2 sides) of about four different thicknesses from http://partsouq.com (you could also check out http://nissan.epc-data.com). The shims from partsouq were pretty cheap - but you do have to factor in shipping cost and time for delivery.
    Don't forget that you should put identical sized shims both top and bottom - this centres the axle vertically and will give your axle seals a better lifespan.
  2. The Following User Says Thank You to Dybo For This Useful Post:
    MudRunnerTD (5th March 2016)
