Page 614 of 1057 FirstFirst ... 612613614615616 ... LastLast
Results 6,131 to 6,140 of 10566
  1. #6131
    Advanced morton2478's Avatar
    Mar 2015
    Cleaned all the snot out of the big girls nostrals lets see how she goes gettin some fresh air in to those lungs !!
  2. The Following 2 Users Say Thank You to morton2478 For This Useful Post:
    BigRAWesty (5th March 2016), threedogs (5th March 2016)
  3. #6132
    Expert SiberianPatrol's Avatar
    Jul 2015
    Siberia
    Mounted an Ironman adjustable front panhard rod. Bracket was in the wrong place for the steering damper so with some fancy Russian engineering, we cut the factory mount and fabricated a new one on the right place.
    1999 GU RD28Ti; mechanical injector pump, 5kBt Webasto circulation heater, 33" Yokohama Geolander I/T, SaaS boost & EGT gauges, 2" Ironman suspension...more to come
  4. #6133
    Patrol Guru Rocket55's Avatar
    Sydney
    All polished and waxed now, it's never looked so clean.
    Cheers Rod
    My Build 2005 TD42TI
  5. The Following 2 Users Say Thank You to Rocket55 For This Useful Post:
    BigRAWesty (5th March 2016), Hodge (5th March 2016)
  6. #6134
    Quote Originally Posted by morton2478 View Post
    what gaskets did you require, look forward to your road report
  7. #6135
    Mar 2015
    Only 3 gaskets required the inlet, 1 on the bottom of the egr pipe that runs down from the inlet and i think its the heater it bolts on to the side of the egr as well it had to all come off to get to the bolts under the maifold a very fiddly job but glad i Pulled it off though
  8. The Following User Says Thank You to morton2478 For This Useful Post:
  9. #6136
    Beginner cltchrystal's Avatar
    Jan 2016
    Fitted some drawers for the beast, made them myself about a grands worth by the time i finished, had to start from scratch with all my tools as I have been overseas for a bit, (14 years) so a couple of hundred on tool. bought the compression handles with locks from a Melbourne company, based a lot of the design on drifter drawers they have some spot on ideas if you don't want to build them yourself, very pleased with the outcome, I will post some pics soon.
  10. The Following User Says Thank You to cltchrystal For This Useful Post:
    BigRAWesty (6th March 2016)
  11. #6137
    Jan 2016
    installed an easy glide drop down fridge slide after the drawer build, wanted to go with the MSA slide but did not have enough time before I had to leave.
    Big 65DZ Waeco fridge had to place on right side of car due to the large slide and fridge to be able to close my back doors.
  12. #6138
    Feb 2011
    Shed
    45 Post(s)
    Kept the hell away from it!
  13. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    BigRAWesty (6th March 2016), threedogs (6th March 2016)
  14. #6139
    Mar 2015
    After a few minor issues after cleaning the inlet maifold yesterday the big girls up and running again very happy with the end result well worth the exercise
  15. The Following User Says Thank You to morton2478 For This Useful Post:
  16. #6140
    No noticeable difference I take it,,,, .but peace of mind knowing its de coked
