Page 7 of 25 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 241
Thread: Now The Drivers Door Wont Open!!!
  1. #61
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    break off the interior trim and replace it with a sheet of aluminium...
  2. The Following User Says Thank You to garett For This Useful Post:
    growler2058 (5th March 2016)
  3. #62
    Feb 2011
    Shed
    45 Post(s)
    Ive had enough for now. I'll tackle it next week and make some calls also
  4. #63
    Remove the door trim on the passenger side door so you can see what your aiming for mate. The mechanisms are all rods. Figure out the rod you need to manipulate on the passenger door and you should be able to come up with a plan for getting to it with the door shut.
  5. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    growler2058 (5th March 2016), Winnie (5th March 2016)
  6. #64
    178 Post(s)
    Not sure that this is relevant, but in the past I owned a sucession of Ford XE's & XF's, well known for busted door handles. On numerous occasions I had to pull door skins off & muck around with connecting rods. The rods operated by the exterior handle & the rods operated by the internal handle were separate. Consequently if the external handle broke, the door could still be opened from inside, & vice versa. The fact that Growler is unable to open the door from both inside & outside unfortunately has me thinking that this is not a 'rod issue' & that getting access into the inside of the door is unlikely to resolve the problem.
    If it is as Wizard posted, the problem part requires access to the actual locking mechanism from the rear outside of the door, & therein lies the problem.
    http://www.nissanpatrol.com.au/forum...-DX-door-locks Post #14
  7. The Following User Says Thank You to Cuppa For This Useful Post:
  8. #65
    I know the Gman specifically want manual windows ,but to eliminate this problem
    would it be worth fitting remote locking, just saying. This would Pi$$ me off no
    end if it happened to me. Would it worthwhile to ring a mobile mechanic to
    come around and have a look. Is there a sure fire fix for this problem or will it re occur?
  10. #66
    burnt the piece of shit and get Agatha back
  11. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    growler2058 (5th March 2016), threedogs (5th March 2016)
  12. #67
    hoping this may help a tad
  13. #68
    hoping thi may help a td
    That's useless mate. He cant remove the trim. Not entirely. The pic may help navigate around the lock.
  14. The Following User Says Thank You to mudski For This Useful Post:
  15. #69
    well he's clutching at straws atm
  16. The Following User Says Thank You to threedogs For This Useful Post:
    mudski (6th March 2016)
  17. #70
    Feb 2011
    Shed
    45 Post(s)
    Yeah it's fukd
    To get in some major damage has to happen. And I'm not committed to that just yet
