Results 1 to 10 of 15
Thread: Air pressure in air bag suspension
    Apr 2011
    In the patrol I have purchased I have red poly airbags in the coil springs.
    What pressure should I run them at
    1. no load
    2. medium load say 1/2 tonne - 1 tonne in trailer
    3. heavier loads
    Nobby
    Legendary timbar's Avatar
    Feb 2011
    perth
    sorry mate i have no idea but im sure someone will have an answer for you soon
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
    The only thing I know about air assist springs is you should keep a minimum 5psi in them at all times to stop them getting pinched by the springs.
    Tony
  4. The Following 2 Users Say Thank You to YNOT For This Useful Post:
    Nobby (15th April 2011), schon55 (27th April 2011)
    Aug 2010
    adelaide
    hi i have them on mine and yes ynot is correct
    the coils do the main work so the airbags are used to level the load so the ass doesn drag on the ground
    when i tow the boat its at 22 psi / if used at this pressure unladen it looks like a wedge or funny car comming down the street
    it is a matter of knowing approx what weight you are putting on
    then remembering what pressure to put in
    or you can just leave it at 18 psi as i do and only inflate for the reel heavy loads
    hope this makes sence
    stephen
    OH LEATHER IS NICE
  6. The Following User Says Thank You to my third 256 For This Useful Post:
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Mine are flat as a tack when not being used ... oopsey ... lol
    I honestly couldn't tell you what I pump them up to - I've only used them twice, and both times just pumped in air until they started to lift the back end and eyed it up from there!! I was in a rush though ... honest! lol. And that was prior to getting the lift, so might be something to play with on the weekend!
    Mar 2011
    also be aware over inflating with 2 much load can break the spring hangers off the chassis
    Oct 2010
    Quote Originally Posted by Ghost View Post
    Never thought you could over inflate them as such (other then rupturing them) - good tip, as I'm a bit ... let's say ... lazy!! lol ... when it comes to things like this!!
  10. #8
    Apr 2011
    How can you determine how much is too much pressure? i do move heavey loads at times up to max. pay load.
    Nobby
  11. #9
    Feb 2011
    Brisvegas
    Generally the red ones are Poly Airs, the blue ones Firestones from the Airbag Man etc.
    Polyair used to state that the airbag had to be inflated before loading up the vehicle. I don't know if that is still the case.
    The blue Firestones (which I have) can be inflated after loading up to get back to level again. From memory the Firestones were at max pressure when they protruded to half the thickness of the coils.
    Min pressure on the Firestones is 5 psi. Max from memory is 30 on GQ patrols. I have never had mine above 20.
    Apparently all airbags that work with coils or leaves reduce axle articulation. Haven't tested it, but it makes sense.
  12. The Following User Says Thank You to Silver For This Useful Post:
  13. #10
    Me, I just "eyeball" the ride height but... Technically, the 'best' way is...
    Let all the air out of the bags
    With average load in the back measure the height front and rear of the vehicle (yes, front as well) use, say, the Bullbar and rear bumper, towbar, whatever to give you a ride height relationship of your particular suspension setup and lift etc. Remember that the vehicle is designed by Nissan to have some load in the back plus fuel etc and not be dead empty so if it is 'empty' maybe take a couple of mils off the measurement.
    Put a couple of PSI in the bags. This is to inflate the bag and prevent possible pinching more than actually adjust the levelling the vehicle.
    If the bum is dragging a bit due to draws or whatever you may need an extra couple of PSI (I run mine at 8 PSI due to a lot of accessories permenantly mounted in the back)
    Whenever a large load is added (Cargo, Trailer, whatever) and the rear sags you should add air pressure until the vehicle ride height relationship is back to the measurement you got initially IE back is 'X' mm higher than front.
    Now that sounds long and involved but it only takes a few minutes really and you only have to do it once to suss out for example
    "Van on and back loaded for trip = 20 PSi,"
    "Roof rack loaded and dual rear wheel carrier with both spares on = 15 PSI"
    As I said, the other method is just wack in some Air till it looks right to the old Mark 1 eyeball.
  14. The Following User Says Thank You to the evil twin For This Useful Post:
