Results 1 to 10 of 13
Thread: Fuchs Oils
    Aug 2011
    River Heads Q
    4 Post(s)
    Fuchs Oils
    Hi all
    Has anyone used fully synthetic Fuchs oils in their vehicles.
    It has been recommended to me and price is considerably cheaper than the Penrite semi synthetic I have been using.
    Normal CFX oil even cheaper.
    Changing to fully synthetic will blow a bit of smoke for 1st oil change but after that back to normal so at that price it would make sense to go full synthetic.
    Any thoughts?
    IMO cheap oil is cheap for a reason,
    I use Penrite diesel 5/40 with no problems at all
  3. The Following User Says Thank You to threedogs For This Useful Post:
    4bye4 (29th February 2016)
    Oct 2010
    Old Bar, NSW
    I know nothing about Fuchs oils, a guy who worked for us had a Peugeot sedan with a diesel engine that went like a cat shot in the freckle.
    He changed to Fuchs and his round town fuel economy improved from 5 to 3.75 litre / 100 klm (foggy memory there) it must be slippery stuff.
    He went to the bikes at Phillip Island and 4 blokes with their gear the thing returned 5/100 at 110kph down the Hume.
    He is very mechanically minded and knows his way round engines, 4B's, bikes etc He was very impressed with the stuff, I have no idea which oil it was though.
    Macca
  5. The Following User Says Thank You to macca For This Useful Post:
    Wizard52 (2nd March 2016)
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    If your going to try it you will find the first oil change as black as midnight on a stormy night
    it cleans every thing out of the engine even the sump
    by the third change it will hardly have any colour in it at all
    up your way id use a heavier grade 5w50 /5w30 seems to thin for the hot weather
    its easy to over fill with full synthetic its hard to see on the stick
    I used Hi-tech full synthetic for a while but found it coming through the gaskets and seals
  7. The Following User Says Thank You to Sir Roofy For This Useful Post:
  8. #5
    Quote Originally Posted by roofy View Post
    A little tip if you cant read the dip stick, when I was repairing underground tanks
    all we did was rub a bit of chalk on the increments and you then should be able to
    see the level
    Sir Roofy (29th February 2016)
  10. #6
    Feb 2011
    Shed
    45 Post(s)
    see the level
    Or put ya bloody glasses on Roofy!
  11. #7
    TRAFALGAR VIC
    35 Post(s)
    Bugger I should have put me sunnys on mate thanks for that
  12. The Following User Says Thank You to Sir Roofy For This Useful Post:
    growler2058 (29th February 2016)
  13. #8
    Dec 2015
    WA
    5 Post(s)
    see the level
    I am pretty sure I don't want chalk in my oil.
    Graham
  14. #9
    Advanced morton2478's Avatar
    Mar 2015
    We used to run fuchs oil and grease in our tractor fleet up here in our machines they would run 24/7 for 9 months of the year and never once had an issue always serviced every 600hrs used it in my old troopy for 3 years and she was the same never missed a beet i would use it again
  15. The Following User Says Thank You to morton2478 For This Useful Post:
  16. #10
    Patrol Guru Irish's Avatar
    Always ran fuchs oil in my bikes & cars back home and they ran like a dream. My mates ran it in their racebikes too.
    Very good reputable oil brand(unless they've been taken over and I didn't hear).
  17. The Following User Says Thank You to Irish For This Useful Post:
