Results 1 to 10 of 11
Thread: over pressurising cooling system.
    Beginner colegate98's Avatar
    Apr 2011
    perth
    hey all i own a 1998 gu patrol with the 2.8 turbo diesel. i have the problem of the cooling system pressurising way to much and spitting all the coolant out of the over flow and eventually getting to low that it starts to get hot. just wondering if any of you guys have had this problem and if so what was the cause?
    cheers ashley
    Legendary big_fletch's Avatar
    Oct 2010
    Tatura VIC
    Howdy mate, welcome to the forum.. People will be more Likly to help if you post up a introduction before asking questions, just as a courtesy to the other members..
    I'm sure someone will be along soon to help you out, enjoy the forum.
    Fletcha
    Qualified Auto-Electrician
    Apprentice Sparky
    Dont own a Patrol or any 4WD at the moment, hopefully will change into the future
    Apr 2011
    I had a 2.8 turbo in a gq wagon and had similar pressurisation. worked out that the head gasket had blown.
    might be worth while getting it checked out.
    had to get head machined and hardness tested and put back together.
    Legendary timbar's Avatar
    Feb 2011
    perth
    Quote Originally Posted by Nobby View Post
    look for bubles in the radiator with the cap off if it blows bubbles get it checked
    1989 GQ LPG / PET TB42 LWB WAGON 4'LIFT 33's
    WELCOME TO THE MUD PITT WE DRIVE NISSAN PATROLS
  5. #5
    Apr 2011
    perth
    ok sounds good im an apprentice mechanic so ill get one of the guys at work to give me a hand with it.hoping its just the gasket and there no cracks.
    cheers for the response
  6. #6
    Advanced _Greg's Avatar
    Sep 2011
    There are generally two problems that cause this issue.
    - if you have a cracked head or blown head gasket, then you will see bubles comming out of your overflow bottle. also smell it, does it smell like exhaust?
    - if you have a blown oil cooler (lower drivers side of the engine), then you will have oil in your water
  7. #7
    Expert T0nka's Avatar
    Jun 2011
    Endless Summer - NSW
    yep cracked head.
    typical from a 2.8. i should know
    I used to cruise... NOW I PATROL!
  8. #8
    Expert beansathome's Avatar
    Nov 2010
    deception bay (QLD)
    just an idea but have u checkd the radiator cap ? it could b that simple
  9. #9
    Aug 2011
    N E Tassie
    as above, try a new radiator cap, try the simple stuff first no point just jumping in and pulling the head without good reason to.
    Also a pressure test of the cooling system should show up a head gasket/ head issue
  10. #10
    Sep 2011
    generally when they go, they are very obvious to diagnose. When mine cracked, it blew all of the coolant out of the engine immediately. luckyly i had a couple of 20l drums of water in the back of the car and was able to limp it slowly back to civilisation leaving the cap off the overflow bottle so it would slowly gurgle in there and not loose too much water.
    you can smell the exhaust fumes in the overflow bottle when this happens.
