Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 112
Thread: Clutch woes.
    Jan 2015
    Canberra
    Thanks mate, do you mind explaining how?
    To bench bleed you assemble the master cylinder and fill the reservoir then manually cycle the plunger until the cylinder is full of fluid. While it is certainly effective, it is also pretty messy. I prefer to fit the system complete then use a vacuum bleeder as it is just as fast (or faster) and I don't have to deal with brake fluid spills.
    WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
  2. #12
    Pretty much what jme said. All your doing is put a hose from the outlet and back into the reservoir.
    So put the cylinder in a vice, loop the outlet into the reservoir, fill the reservoir and push the piston using a screw driver until all bubbles are gone.
    It can be messy but it doesnt have to be. The messy part is when you undo thd outlet fitting and put the clutch hose fitting in. You will drip a bit there. But otherwise its o.k.
  3. #13
    I bought new master and slave cylinders from Patrolapart (genuine nissan) and fitted them this arvo.
    Got a mate over to help bleed it with me, used a bottle of fluid and spent an hour and it still has air in it... I think I will try the vacuum bleeder.
  4. #14
    Thomastown, Melbourne
    6 Post(s)
    Funny i have never had an issue bleedy my clutch..
  5. #15
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    pump with a full stroke and slowly.... slowly. make the pedal come up slowly down slowly. works every time for me. and bleed from pas side guard till your happy then move to the slave.
  6. #16
    What is the gravity bleeding method?
  7. #17
    Jan 2015
    north
    21 Post(s)
    keep master full and crack nipples then wait. (general idea)
  8. The Following 2 Users Say Thank You to garett For This Useful Post:
    threedogs (25th February 2016), Winnie (24th February 2016)
  9. #18
    Bloody car! Was at it again for hours last night.
    I have tried everything from the syringe method, gravity bleeding, pumping the shite out of the clutch while the nipples were open and the old fashioned way.
    Get a tiny bit of air through very rarely every now and then doing it the old fashioned way.
    I can get the car into gear while the engine is running now but I have very little movement in the clutch pedal until it starts to grab.
    Something is still not right.
  10. #19
    would re-newing your vacuum hoses help, seems like you've done all you can bleed wise.
    Like you said you're missing something
  11. #20
    Vacuum is only for assist though so I don't think that would help.
    I did find one vacuum leak last night though which I fixed but it did not help me to bleed.
  12. The Following User Says Thank You to Winnie For This Useful Post:
    threedogs (26th February 2016)
