Results 1 to 10 of 12
Thread: King springs with Koni shocks 2" upgrade and actual lift
    Jan 2014
    Shepparton VIC
    Hi,
    Hope all of you are having a great weekend.
    Last week I upgraded my 2012 GU suspension with King springs (KDFR-42 / KDRR-45) and Koni 82's.
    I measured the heights from center of hub to bottom of flare and find out the lifts as follows:
    Front
    Passenger side: 27mm
    Driver side: 28mm
    Rear
    Passenger side: 34mm
    Driver side: 28mm
    Are these lifts reasonable?
    The riding is exactly what I wanted but not sure about the lift.
    My car only has an alloy bullbar/driving lights, dual battery and tow bar, nothing heavy.
    And I also like to extend the sway bar links but do I have to extend as per my lift measurements. By looking at the bar in rear the passenger side bar is lifted more than the drivers side.
    Do I have to extend the front links as well?
    Thanks all.
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
    You will find there is a RH and LH coil for
    the front to compensate for the drivers weight
    Jan 2014
    Shepparton VIC
    Yes TD it was installed accordingly.
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    mine is a gq but i did king springs as well. but a progressive rate spring, got 50mm but they settled down a bit. bout 15mm soooo put in 15mm spring matts
  5. #5
    Jan 2014
    Shepparton VIC
    Hi Garett,
    Mine is just installed not sure whether it will settled after sometime. Did you get exactly 50mm all around?
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  6. #6
    Jan 2015
    north
    21 Post(s)
    to start with about 50mm, took photos on my build thread. mine was sagged. 24 years before they got changed. the drivers side was lower than the passenger on the old springs. so if its a bit high on the drivers side new i wouldn't worry it'll sag first.
    think mine were KDPR-43 KDPR-42. but mine is a lighter car and i think they quote the same parts for both GQ and GU.
  7. #7
    Jan 2014
    Shepparton VIC
    I talked to King springs and I was told that if I need 50mm lift I should have gone for
    KDFR-42H and KDRR-45H
    My current setup KDFR-42 and KDRR-45 are actually 30mm lift which is what I am getting now (so my measurements are spot on).
    I need to talked to the local supplier and see what his thoughts are. Not sure what will be the outcome though.
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
  8. #8
    Mar 2016
    Quote Originally Posted by escix View Post
    Hi,
    Front
    Driver side: 28mm
    Rear
    Driver side: 28mm
    Thanks all.
    About a week ago I changed the suspension of my 2009 DX to kings and koni 50mm. Im having the same issue, passenger rear side is 20mm higher then driver side!! I asked 5 different suspension centers and non of them can tell me what could be the problem lol
    Did you find it out or solved the problem?
    Thanks.
  9. #9
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    I just put in kings and koni's a couple of days ago and front was uneven before with new gear it rose 65mm and 75mm so now even both sides and same on the back. The rear sits 10mm higher than the front which to me is pretty spot on. Need to get extended sway bar links for the back though. All good.
  10. #10
    Jan 2014
    Shepparton VIC
    Quote Originally Posted by nissanturk View Post
    Thanks.
    Yes, I changed the springs to KDFR-42H and KDRR-45H free of charge and all good now, almost all heights are 585mm from hub center, very happy with the outcome.
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
