Hi Guys, GU motor is coming up 380,000 km and still going strong. Change oil when needed and get tappets done when needed too.
all great with motor and no oil leaks. is the motor life up for another 380,000 km or I'm I dreaming regards Alex
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
Why worry, you can buy the engines for a song now
I just sold mine with 136000 on the clock for $1000.
John
Providing you take good care of her, keep the fresh oil in it, i wouldnt be stressing.
I have 300 on mine and she still starts first go everytime regardless of how long she sits
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me)
altech (19th February 2016)
Yes, you're dreaming, but what do you care?!!
Lot can happen during that time and you can end up getting another fourby or swapping the engine for peanuts.
The motor has been serving you well by the sound of it.
Look after it and enjoy it. Don't think too far ahead when it comes to motor vehicles. They are what they are.
Few more mods on the way
https://www.panthera.org/
Cheetah Outreach
Some GQ 4.2s have 750k on them and the 4.5 is basically a bored out 4.2
you should have plenty of Kays left if serviced right
Cheetah Outreach
altech (20th February 2016)
The 4.5 is a totally different engine. Alloy head and totally different block. It uses a timing chain, the TD42 uses gears.
They are "swappable" (I've just done mine) inasmuch as the engine mounts are in the same place and they have the same transmission fitting (as does a ZD30).
Exhaust manifold is same bolt pattern as is viscous hub & fan.
No alternator, steering or A/C brackets fit. Coolant inlet/outlet are totally different.
John
altech (2nd March 2016)
