Page 126 of 187 FirstFirst ... 124125126127128 ... LastLast
Results 1,251 to 1,260 of 1862
Thread: MudRunnerTD's GQ From the Ground Up
  1. #1251
    Very helpful thanks Kallen. I was pushing today. Cheers mate.
    BigRAWesty (15th February 2016)
  3. #1252
    Here is a better pic of the gap I was dealing with. Not too much.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Clunk (29th February 2016)
  5. #1253
    Looks good Darren. Can't wait to drive Mt Sunday with you!
  6. The Following User Says Thank You to Winnie For This Useful Post:
    MudRunnerTD (15th February 2016)
  7. #1254
    That's not a gap.........lol
    That's a peno gap..
  8. The Following User Says Thank You to BigRAWesty For This Useful Post:
  9. #1255
    Yeah the gap shown in the first pics is what it looked like after I cut the plates off to show the angle difference. That's how much I had to trim. Got them pretty close.
  10. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (15th February 2016), threedogs (15th February 2016)
  11. #1256
    You've mounted them the same as I did on the troopy, I drilled and tapped 4 holes with 1/2" UNC thread,
    in the corners of some 12mm square plate, then welded those plates [3] to the chassis then bolted the
    steps to them. Must admit as you would know they are as strong as. You can jack the whole side off
    the ground they are THAT strong.
    No name cooking spray is way cheaper than anti splatter, smells better too LOL
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #1257
    Jan 2016
    Arusha, Tanzania
    Ok been busy under the hood over the last month. I am getting a few things sorted while it's parked up. I am getting it ready for a bigger airbox and hopefully a stainless snorkel through the bonnet at some point.
    I have moved the Fuel Primer pump and the vacuum tank to the drivers side and stripped a heap of other crap off the fire wall. I removed the clutch bleed hose and tube and replace the hose and block to allow for the removal of the extra bleed.
    This is a Big Job and will take some nutting out to put Humpty Dumpty back together again but it's getting there
    Before.
    Attachment 52115Attachment 52116
    Fuel primer now attached to drivers side battery tray just above the fuel pump. The copper fuel pines across the fire wall are gone.
    Attachment 52118Attachment 52119Attachment 52120
    I relocated the vacuum tank and used the copper tube as the primary supply to the tank rather than from the tank just to the clutch
    Attachment 52121Attachment 52122
    Getting there
    Attachment 52123Attachment 52124
    Stripped out the clutch bleed valve as it's pointless. Phill at the 4WD Shed sells a replacement hose and block without the bleed for the win.
    Attachment 52125
    Removed the redundant dual battery solenoid and wiring and pulled back a few wires that were no longer being used.
    I am going to move the fuse block and have to remount it and sort out al the accessories that were going to the second battery that no longer exists. A bit to do yet but it's coming together
    From this
    Attachment 52115
    To this
    Attachment 52126
    To this
    Attachment 52127Attachment 52128Attachment 52129Attachment 52130
    Coming together.
    Hi Mudrunner,
    Please can you put up some more pics if you have them of the current positions of all the fuel lines and clutch etc and how you managed to mount them? I'm keen to add a snorkel and dual battery setup under the hood on the passenger side. The clips holding the current lines are all buggered on my GQ so I would see moving these as a win-win.
    Cheers, Chris
  14. #1258
    Bugger sorry Chris I will sort out some pics for you mate
  15. #1259
    So did a bit to my weld on rack on Sunday. I am going to add a flat rack to the back so I can carry a bit of fire wood or whatever. The cross bars are there so I might as well.
    This is how I bought the bar work
    I cut it off that roof some time ago and have been planning it for ages. Time to get it done.
    So I'm going to add 5 bars running front to back then weld mesh on top of that. As I said, it will not change the height of the rack at all so I might as well.
    I cleaned off the paint at the 5 points so I could weld the new tube on.
    I test fitted the first one.
    So I don't have a notching machine but watched a pretty cool YouTube vid a few months ago which explained notching without a notcher well. Piece of piss!!
    So. This is how it's done.
    ________________________
    Measure your tube diameter.
    My tube was 25mm.
    This system uses 1/3s. Divide the diameter of your tube into 1/3s. My tube is 25mm so 8mm is approx 1/3.
    My tube needs notching at both ends so I ADD. 1/3 to both ends (16mm) and cut to length.
    Put a mark on top and bottom of tube dead centre. (The longest part of the notch)
    Now put a ring around the tube 1/3 back from the end (8mm on my tube)
    Now place the tube in your cut off saw. Centre mark straight up. You want to set the angle of the cut to be end of tube at the centre line back to cutting on you 1/3 line on the side.
    Then spin the tube over and your bottom centre Mark will let you do the opposing cut.!!
    Your Done!!!
    Clean the up with a grinder if needed!
    Straight off the cut off saw!!
    Come up good I think. Need to clean up my welds and weld the mesh on top. Then strip all the paint off it and prime and paint ready to weld onto my roof!!
  16. The Following 5 Users Say Thank You to MudRunnerTD For This Useful Post:
    Clunk (29th February 2016), growler2058 (29th February 2016), Kimbo63 (2nd April 2016), NissanGQ4.2 (29th February 2016), threedogs (3rd April 2016)
  17. #1260
    Looks very good Darren!
  18. The Following User Says Thank You to Winnie For This Useful Post:
    MudRunnerTD (29th February 2016)
