Page 604 of 1057 FirstFirst ... 602603604605606 ... LastLast
Results 6,031 to 6,040 of 10561
  1. #6031
    82 Post(s)
    Fitted a small plug with a water proof inline fuse to plug the solar trickle charger. I used the plug's pair as a waterproof cap. The only thing I don't like about it is that the positive is the exposed pin.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    rusty_nail (12th February 2016)
  3. #6032
    I just brought this waterproof 50 amp anderson plug casing that might do that better,
    even has a very small led to let you know you have power going to the plug
    http://www.ebay.com.au/itm/RED-50Amp...item1c60b6fbc6
  4. #6033
    82 Post(s)
    Only .1 Amps (100 mA) maximum, TD. That plug would be overkill. Wouldn't mind having a plug like that with an isolating switch and voltage spike protection, to use with jumper cables though.
  5. #6034
    my jumper leads cost $200 they weigh a ton and have spike protection
    Why not just reverse the polarity on the plug to suit your needs??
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Stropp (11th February 2016)
  7. #6035
    82 Post(s)
    I suppose I should as all of the connections from the vehicle are the same, which makes it easy to short out the battery or blow fuses on the sockets.
  8. #6036
    I used one of those trickle charge solar panels for a while , yes just on 1mili amp.
    enough to keep the battery busy imo
    Now I have a 20 watt panel to do the same thing.
    mudnut (11th February 2016)
  10. #6037
    Nov 2010
    Getting a life...
    38 Post(s)
    Locked her away in the 'big' shed.
    I'm a cruiser man now.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  11. #6038
    Thomastown, Melbourne
    6 Post(s)
    click bait.
  12. The Following User Says Thank You to Bloodyaussie For This Useful Post:
  13. #6039
    100s or 200s or 70s ??
  14. #6040
    Nov 2010
    Getting a life...
    38 Post(s)
    Worse. The 60 series.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  15. The Following User Says Thank You to katwoman For This Useful Post:
