Its a Nissan! =====> Its a Keeper!! ....... Got a TD42 in it BONUS!!....... I'm a lucky bugger! I've got 2 of em!
BigRAWesty (9th February 2016)
You would probably use the standard clamps that Arb use for the bull bar but the camburgs on the sliders for both front and rear scrubs.
They are a seamless"ish" fitting.
They would be great to use on a full external cage to easily replace sections if damaged but still looking one piece.
MudRunnerTD (9th February 2016), mudski (9th February 2016)
And also ease of dismantle for maintenance / compliance release !
Monkey Grip, Super Strong, Top Idea MRTD :-) !!
AB (9th February 2016), MudRunnerTD (9th February 2016), Winnie (9th February 2016)
Nah not really, I bought them with a few mates me we did a group buy and got a great price.
I called ARB for a price for the bullbar brackets they use on their older style brushbars. They cost $46.30 for a set including bolt and I might go that way for the GUIV brush bars. The camburgs are perfect for removing damaged aections of bar work. Even just to repaint the bar work will be a winner. These will nearly be invisible. I'll use a camburg to joint the rear scrubs to the rear bar and sliders and the front arch a to the front bar. I think the camburg a cake in around $30 each.
Nice work Dazz!!
The price don't really come into effect if you want the job done right!
________________________
______ 2017 D-Max _______
MudRunnerTD (9th February 2016), threedogs (14th February 2016), Winnie (9th February 2016)
If you build them properly and still damage them enough to rebuild or replace sections, there will be more pressing issues that need attention before the barwork.
I tagged you in a set this morning, they're good. I personally navigated the owner into a position where they were needed to do their job and they did it just fine
96 GQ coil/Cab
08 G6eT
AB (10th February 2016), BigRAWesty (10th February 2016), MudRunnerTD (10th February 2016)
