Results 1 to 10 of 26
Thread: Knock in front end when turning left or right.
Threaded View
  1. #12
    Quote Originally Posted by Wetty View Post
    Just loosened the nuts and checked the holes. . . . and what do you know, I have elongated holes, about 1mm on each side! My next question now is, how do I fix them? I was thinking of getting some heavy duty washers the same size as the bolt and welding them to the hangers, but then I'd need longer bolts to account for the washers.
    Andrew
    Grab some weld on washers from threedogs.
    You'll need 8 and 4 new m16 grade 8.8 bolts 110mm long preferably in a metric fine thread..
    Remove bolt, insert a washer either side, tighten and the weld them on..
  2. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Wetty (6th February 2016)
