Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Td42 info
    If you have a budget, then build to it. I had some mild head work done to a brand spanking TD42t head on my build. Porting, stellite valves and stronger springs.Is it worth the money. Don't know. As I went from a ZD to TD I had nothing to compare it with. I suppose you need to work out what you want out of the motor. Then kind of design the build from there. No point putting all the biggest and best gear on their only to run it totally stock.
    How is Bens motor going Mat? Back up and running?
  2. #12
    Dec 2013
    Australind WA
    Cheers for the link that was a good read. Gave me a lot to think about. Definitely gonna put better internal components and I'm thinkin I'll get as much done to the head and my funds allow. I've found a second hand denco turbo kit if it's all sweet might go for that if not I liked the safari kit on my old work ute that thing used to hum along.
  3. #13
    22 Post(s)
    Quote Originally Posted by Shaft10 View Post
    You dont really need headwork. I spent 3k on the head using the original, and doing the porting myself, which took a good 35 man hours to do x at least $70/ hour if you paid for it. Its uncalled for, for what you are saying you want out of it. You are already looking at $1k getting the head cleaned up as it is.
    Just get turbo pistons ( you can get them to suit a 28mm gudgeon), turbo oil pump, new harmonic balancer and make sure you balance the engine. Pistons and rods individually and full rotating assembly including flywheel and clutch. Thats all.
    Please dont put a second hand denco junker on a new engine. Get a new gtx 2863 or ufi16g or some thing new
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    BigRAWesty (5th February 2016)
  5. #14
    Dec 2013
    Australind WA
    Funny u say that bene was talkin to my cousin last night who will be helping me and said same thing ha h so yes will be putting new turbo on it. When it comes to turbo pistons are the ones engines Australia sell the go or would you use something else. I know 2 people who have melted Pistons in their cruisers so wanna make sure I get the right ones as I've been talkin the td42 up a fair bit
  6. #15
    Dec 2013
    Australind WA
    My cousin also mentioned mahle Pistons never heard of them any1 know much bout them
  7. #16
    Mar 2015
    Mahle pistons oh the memorys of building a red hot 1380 for my mini mahle pistons where the big cheese to have back then were quality gear cant say now but yeah........
