Results 1 to 10 of 11
Thread: Light Bars
    Expert altech's Avatar
    Nov 2011
    Rupanyup, 3388, VIC
    Light Bars
    Hi Guys, just purchased a light bar from ebay , Very well made with Cree globes . so it last for awhile. My ? is when is the good time to put it ON . eg night / day or driving on main roads or just bush . Are they legal ? . whats the Min install Hight ? regards Alex
    97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
    The way you have it installed is legal.
    It must be wired to a switch, which is also triggered by high beams. So the light can only come on when that switch is ON, and you have your high beams on.
    I use mine night driving, turn off on main roads or near houses.
  3. The Following User Says Thank You to Winnie For This Useful Post:
    altech (4th February 2016)
    Nov 2011
    Rupanyup, 3388, VIC
    thanks Winnie cheers Alex
    Nov 2011
    Rupanyup, 3388, VIC
    Hi just a ebay link as it was a bargain regards Alex
    http://www.ebay.com.au/itm/261508330...%3AMEBIDX%3AIT
    Hard to see from the angle of the piccy but if part of the Light Bar protrudes in front of, or is higher than the Front Bar, or if any gap is large enough to catch an extremity of a pedestrian you just mashed then it is technically illegal.
    Would be unlikely to get Constable Plods' attention unless you were being a tosser tho...
  7. The Following User Says Thank You to the evil twin For This Useful Post:
    Nov 2011
    Rupanyup, 3388, VIC
    So It's only a Nissan Nudge Bar does that count when hitting Pedestrians = lol
    Quote Originally Posted by altech View Post
    Does it hurt if you jump off it and land on their spleen? :-)
    I reckon Front Bars should come with an inertia loaded piece of round stock that swings out under heavy braking and cracks Pedestrians across the shins when they step out in front of a vehicle they didn't see 'cause they are too busy texting
  10. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    altech (4th February 2016), Bigcol (15th February 2016), gaddy (4th February 2016)
  11. #8
    Nov 2011
    Rupanyup, 3388, VIC
    Hi Guys , after days going to work I was hearing this Whistle noise coming from front of truck , hmmm must be the light bar , so I drop it about 2 inchs . Sound has gone away and looks better regards Alex
  12. #9
    It looks more legal there, are you happy with the output [light]
    Nudge, mame same thing in Mr Scruby's eyes, Grrrrrr
  13. The Following User Says Thank You to threedogs For This Useful Post:
    altech (10th February 2016)
  14. #10
    Nov 2011
    Rupanyup, 3388, VIC
    Nudge, maim same thing in Mr Scruby's eyes, Grrrrrr
    Light is "Out There " don't need to use Spot lights now lol regards Alex
  15. The Following User Says Thank You to altech For This Useful Post:
    threedogs (10th February 2016)
