Page 53 of 101 FirstFirst ... 5152535455 ... LastLast
Results 521 to 530 of 1003
Thread: Hodge's new 4.2
  1. #521
    May give Mark a ring. He might have a stockie lying around you could use, for now.
    That cooler will be better than what you have i reckon. For sure. if you must do this now you dont have much option. Id just leave it for now until you can get what you want....
    Hodge (2nd February 2016)
  3. #522
    177 Post(s)
    Might go see Mark.
    I don't think I'll go to CC or HPD in the near future, as I doubt I'll tinker with a different turbo, maybe just air intake increase thats about it.
    So don't have much choice.....
    The fact the oil leak out of the IC is so sudden is whats got me confused as I was under there yesterday morning and it weren't there. So if it's cracked between then and now, I'm concerned it may let go further on when I leave friday and weather is warming up etc...
    Patrol Guru Rocket55's Avatar
    Sydney
    Bugger mate. I just sold my stock cooler set up as well, although bit of a trek to get it.
    Cheers Rod
    My Build 2005 TD42TI
  5. The Following User Says Thank You to Rocket55 For This Useful Post:
  6. #524
    177 Post(s)
    Thanks mate. It's not a biggie its just an IC, the fact it decided to surprise me with a patch of oil instead of the usual "sweat" of oil like the grenade intercoolers... is whats unusual. Worst case is just drive with with . What on earth could happen lol.
    That eBay unit looks alright, but it could be just chinese junk..
    Might go see Mark.
    Well if your gonna leave the stock turbo on i would give that ic a go.
    Hodge (3rd February 2016)
  9. #526
    There shouldn't be that much oil in the IC?
  10. #527
    No catch can mate. He'll have a bit. Enough for it to drip out of a hole.
  11. #528
    Make your own top mount of using a fmic. There is nothing wrong with having a real good intercooler regardless off turbo but if your worried about quality and dont wanna fork out for a cc then have a look st the ARE items which are a direct replacement.
  12. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    Hodge (2nd February 2016), mudski (3rd February 2016)
  13. #529
    177 Post(s)
    I have run out of time, so the leaking IC will go to the high country with me... Just hope it doesn't split open further ....
    Thanks Matt.
    I was under the impression, by word of mouth and from reading somewhere from memory that , larger intecoolers such as the CC one, create too much air volume for the factory turbo to push through... So unless you have a larger airbox, larger intake (4" for example" and a bigger and/or better turbo, the much larger IC are not as efficient ??
    As I said, I vaguely remember reading this a few times. It may or may not be right ...
    I don't intend on upgrading the turbo or anything like that in the near future. But when and if I do, I'll just do the whole lot, 4" intake, turbo, pump etc.. But that is not on the horizon for some time.
    For now, Maybe a higher flowing air box such as the HPD Cobra head maybe or the fatz airbox like a few here run, just to make the 4.2 breathe a bit better ... and a better intercooler which now I actually have to do.
    I've had a look at the ARE (I was wrong in my post earlier, they DO actually have a 4.2 / 2.8 one). HPD also do a good one supposedly...
    Yeah nothing wrong with hpd mate.
  15. The Following User Says Thank You to mudski For This Useful Post:
