Page 16 of 38 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 380
Thread: Extreme 4X4 day trip to Wesburn 30/1/16
  1. #151
    Yeah most likely. He was going to keep pulling things apart then have a chat tomorrow to make a decision. Looking forward to it. At least ill have got on top of the flat spot and fuel starving issues.
    Dont stuff about. Much easier to run a 12mm at lower figures than trying to lean on an 11mm pump. 12mm pumps just work nicer by nature. And as winnie has pointed out once the pump is sorted you can then pretty much pick the turbo you want simply by how much power/torque you want/need.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    Winnie (2nd February 2016)
  3. #152
    Yeah cheers Matty pretty much my thoughts ☺ . . .
  4. #153
    Patrol Guru matfew's Avatar
    Nov 2012
    We still doing Saturday? Thinking I might be able to throw a trailor behind someone's car and just lock the trailor up at that car park. Is the car park a hot spot for thieves?
  5. #154
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by matfew View Post
    It is now!
    >>>tappin from tassie
    Hello from Under Down Under!
  6. The Following User Says Thank You to taslucas For This Useful Post:
    BigRAWesty (2nd February 2016)
  7. #155
    Yep it's on. Don't think it's too bad it's kind of next to a main road. There's a couple of k of bitumen up to the track is not far tho. Not sure what kind of loop we're doing or which way where headed back yet guess think we were planning a reasonable look around the area and see where it takes us.
    I've confined a 12mm pump and injectors from dieseltec so according all goes to plan will be ready by the weekend. Apparently the front seal had been leaking pretty bad for a while and the pump had a fair bit of oil in it. . . Hoping it should be good. . .
  8. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    BigRAWesty (3rd February 2016), Bloodyaussie (2nd February 2016), Sir Roofy (2nd February 2016), Stropp (2nd February 2016)
  9. #156
    Wow you won't know yourself then! Must be pretty excited for it hey Ross?
  10. #157
    Yeah, well the reason i say hope so is cos won't really know how it performs with current turbo until it's up and running. Andrew didn't want to make any promises and said it could be pretty reasonable or marginal gains. Guess we'll find out just don't want to set my hopes too high and have them end in tears!!
  11. #158
    we all know the turbo ic upgrade is next on the cards now. It's inevitable!
  12. The Following 4 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (3rd February 2016), Rossco (2nd February 2016), Stropp (3rd February 2016), Winnie (2nd February 2016)
  13. #159
    Looking forward to having sum fun in the fourby are we still planning pizzas afterwards?
  14. The Following User Says Thank You to Rossco For This Useful Post:
    Winnie (3rd February 2016)
  15. #160
    Yeah it's been a while since I had a good session... I reckon mt Sunday with you and Geoff was the last serious 4wding I did haha.
