Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: ZD30 belt tensioner
    Quote Originally Posted by roofy View Post
    Once you get into the fine dust it will let go
    just a wee squeak then get worse over time
    @Kallen get one of E/bay and put in your spare kit
    Just seen all the kits with belt and tensioners and was wondering if it's needed..
    I have the original on at 220k with no signs of changing it yet
    Yours hasn't seen dirt for 220k too John...
    Dirt kills these tensioners easy. I destroyed a almost brand new one when I got stuck neck deep in that bog in Tallarook.... If I were Kallen, I would replace the entire unit when doing the belt, and keep both old belt and tensioner as spares in the truck, along with a MAF. Because if you spit the tensioner anywhere and you dont have a spare, your fubar.
    Hey Kallen, strap your thinking cap on and make up a stainless guard for the a/c pulley. The idler bearing in these cops a hell of a lot too because its so low down...
    BigRAWesty (12th January 2016)
  4. #23
    177 Post(s)
    Agree with Mudski. They don't like dirt. I killed 2 in span of 3 months.
    Both let go after a day of ofroading .
    Tapatalked from S6
  5. The Following User Says Thank You to Hodge For This Useful Post:
  6. #24
    Cheers guys..
    And yea mudski I was looking at that.
    I guess that why they have that stupid big plastic sand catcher under them..
    [QUOTE=mudski;652964]Yours hasn't seen dirt for 220k too John...
    Not entirely true its goes to Tallarook a few times a years with some mates and up along the Murray as well
    Just cause I dont go on trips from here doesnt meant I dont go 4x4ing. Id go more often if health was better
    Also been up and around Woods Point a couple of times too. in the GU
    As suggested change out what you can hose,belts, maf etc then you know where you are and keep all for spares
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #26
    Ok guys had a rather large squeal from start up yesterday morning..
    It disappeared by the time I had popped the bonnet and got to the front to investigate..
    It just stopped..
    I did notice when I got back in that the ac was on..
    Hasn't done it again.
    How likely is the ac bearing to fail??
    It just stopped..
    I had changed the idler bearing in the a/c twice in 18months. Remove the belt and spin the a/c pulley to see if theres any play. I always kept a spare bearing for the a/c.
    Best thing to do is replace the tensioner and belt. The tensioner with oem only in my opinion. Ive had a few issues with the aftermarket jobs. But get one of them as a spare uhder the pax seat. If the tensioner or belt goes while your out. The car wont be going any where.
    As for the belt. Oem or gates brand. I ran either and either worked really well.
    But keep a tensioner, belt and maf with the tools required to replace in the car mate. I kept all mine under the pax seat.
    Any of these go when your out and you cant change them over, call a tow truck.
    Oh yeah. I dont have the tensioner from mine anymore too bud. Sorry.
    BigRAWesty (1st February 2016)
  12. #28
    To easy mate. Yea I gotta get a few things happening before may..
    I think scangauge may have to wait a little..
    Mar 2016
    Canberra ACT
    I just had my drive belt & tensioner replaced after having a similar squeak, i went with OEM from Nissan. $270 for tensioner & pulley, $75 for the belt, kept old ones for spares.
  14. #30
    I basically rebuilt mine. Bushes were fubar so I got the vesconite ones from Armstrong Energy. Got bearings from local bearing shop (i think one was ever so slightly wider). Used fork oil for ensure oil in the spring housing.
