Results 11 to 20 of 36
Thread: GU centre console removal
    This is the bit I want to remove if poss.
  2. #12
    Righto...
    Shifter bit...
    Remove the front screws, 2 off, LHS and RHS under the little placcy screw cover thingies
    Remove Ashtray
    Remove screw under ashtray
    Lift Shifter bit far enough out of the way to access the two screws holding the front opf teh armrest console to teh tunnel.
    Armrest...
    Remove the two screws as above
    Remove screws, 2 off, LHS and RHs of rear of console low down near front seat rails
    Armrest rear Trim...
    Remove 'super secret, pain in teh arse screw' that is above rear ashtray LHS and remove trim
  3. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    threedogs (31st January 2016), Zoc (23rd August 2017)
  4. #13
    This is now a Monday job , GRrrrr
  5. #14
    Righto...
    Armrest...
    You should need to remove these. IIRC. Only the two rear side ones near the seat rails.
  6. #15
    Im trying to fit this at the bottom of that switch panel for my UHF mike.
    on top of that I want to install a double USB port I have some material
    here to make a switch holder that will fit that area. we'll see how I feel tomorrow
    pretty sore today which doesnt help. So many 12 volt jobs to do, very hard
    even though my son is an auto elect
    http://www.ebay.com.au/itm/Pro-Netwo...EAAOSw~bFWQG8p
  7. #16
    I just used an RJ45 wall socket one from Middy's and adapted it to the panel below the dash and glued the front bit on, so its flush.
  8. #17
    Yeah But that area is full on my Patrol, but yes its a RJ45 panel mount with two screws.
    I have a remote head UHF so everything is hidden,
    I'll be leaving the Mike in the glovebox until needed.
    I do have that Baintech USB outlet in the same position, but not sure Ill be leaving it there.
    Going to re think how it all goes, have most of the bits and bobs to do it,
    but dont want leads or wires getting crossed over, going to put another USB outlet on the back of the console
    as well
  9. #18
    Yeah that Baintech USB socket is crap. Useless for charging as its only 1amp. My tablet and phone will still go flat when plugged into it. Need a minimum of 2amp these days. Something else to change....
  10. #19
    Yep... only need to do that one if you want to remove trim (orig post edited)
  11. #20
    Aug 2014
    Perth
    10 Post(s)
    I'm trying to do this to get to the back of the centre console so I can mount my new UHF there. I've removed the first bit undid the screws mentioned but it still seems to be held in by something. Any ideas? Looks like someones tried to staple the base I can see two divets with what looks like staples in them, its the only thing I can think off thats still holding the centre console in place.
