Page 219 of 570 FirstFirst ... 217218219220221 ... LastLast
Results 2,181 to 2,190 of 5693
  1. #2181
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Drivers door window regulator and motor.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  2. #2182
    Didnt buy it but going to make two round plates about 4" in diameter
    and welding a piece of 1.5 pipe about 76mm high to support the awning poles in sandy ground.
    Ill get them powder coated a bright colour so I dont lose them.
    The laser cutter is forever throwing out round disc's of every size you can think of.
    Something else to take ,,,yes but I think it'll come in handy.
  3. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (23rd January 2016), gubigfish (26th January 2016)
  4. #2183
    That sounds like a good idea. .
    Can use for car awnings or tent awnings in sand or just soft ground..
    4" may be a bit over kill..
    I think 60-70mm would do..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    threedogs (23rd January 2016)
  6. #2184
    I have 100mm here thats why I mentioned that size lol
    not much difference I suppose from 76 to 100mm, both
    would work
  8. #2185
    Fair enough..
    Provent is on its way
    Aug 2014
    Perth
    10 Post(s)
    purchased a 4" ram head for my snorkel instead of the smaller one supplied by millweld
  10. #2187
    Feb 2011
    Shed
    45 Post(s)
    New mirror.
  11. The Following 2 Users Say Thank You to growler2058 For This Useful Post:
    BigRAWesty (27th January 2016), Clunk (27th January 2016)
  12. #2188
    Some 6mm push air fittings have arrived, so now I can plumb up my air horn
    and air tank, when I fit my Pro-locker its then just a matter of fitting a TEE in the system
  13. #2189
    Aug 2010
    adelaide
    [QUOTE=growler2058;656012]New mirror.
    glass mob on regency road took a template and cut mirror for me $15.00 and i used doublesided tape to atach or they will do it for $40.00 installed
    you could go to some one closer to you just trace out th stape
    OH LEATHER IS NICE
  14. The Following User Says Thank You to my third 256 For This Useful Post:
    growler2058 (27th January 2016)
  15. #2190
    Jan 2014
    Shepparton VIC
    Bought this earlier but didn't work but the supplier sent me another one and which works perfect with my iPhone.
    http://www.ebay.com.au/itm/Car-Auto-...73?ssPageName=
    2012 CRD:
    DIYs;
    RedArc Dual battery
    Hifonics audio amp
    Reverse camera
