Results 1 to 5 of 5
Thread: mounting Auto to the Engine
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    Hi i expect theres an easy answer but i cant see it so here goes...i was told to fit torque converter into box and make sure its in the iol pump nice and snug done that.lowered the engine with flexplate fitted and torqued located the dowels have drawn the engine and gearbox together. So the question is i cant see or feel the torque converter to line it up with the flexplate, i have the lower cover off can see the flexplate but can not reach over it to the converter. What to do?
    Many thanks Pezzer
    Rotate the engine to line a bolt hole up then rotate it as one to get the others in.
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    Pezzer (23rd January 2016)
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    A time saver is to set both the TC and flexplate to 6 o'clock before mating engine and trans
    John
  5. The Following User Says Thank You to jff45 For This Useful Post:
    Jun 2013
    Gold Coast
    If i bolt the faces of the tranny and motor fully up i cannot get my fingers in the gap to locate the bolts...
    Jun 2013
    Gold Coast
    All done finally....
  8. The Following User Says Thank You to Pezzer For This Useful Post:
    jff45 (23rd January 2016)
