Results 1 to 10 of 14
Thread: Dual Dawes report
Threaded View
    Gold Coast
    Dual Dawes report
    About two years ago I installed a dual dawes setup-first with a TPS switch and electronic control, then with a simple "high/low" manual switch. I ran 10 psi low and 17 psi high. Logic was to save on fuel with low boost when puttering around.
    Watching fuel consumption over two years I have discovered there is virtually no fuel saving, EGTs are similar, and the GU certainly runs better on the higher boost.
    Final outcome--I removed the low boost dawes and now run a single system.
    BTW, anyone needing a dawes valve should PM me.
  2. The Following 3 Users Say Thank You to Dr Gary For This Useful Post:
    BigRAWesty (20th January 2016), mudski (21st January 2016), threedogs (20th January 2016)
